Help bird crap damage!
Old Jun 7, 2009 | 02:01 AM
MARSC6's Avatar
MARSC6
I would try meguiars scratch x first. I use it after wetsanding to polish the small interior parts I paint. If it works for that it should remove the spots.
Old Jun 7, 2009 | 02:09 AM
c6 batmobile's Avatar
c6 batmobile
Clay bar will take it right out. I know this from experience.
Old Jun 7, 2009 | 10:36 AM
Wilzer's Avatar
Wilzer
Originally Posted by twfreightman
If I had the same problem, I would start with a solution of 50-50 vinegar and water and wash the spot with a soft cotton cloth.
To the best of my recollection, bird guano is a caustic alkali and not acid, actually the opposite. When I get bird calling cards the next time, I'm going to try the weak acid i.e.vinegar - THANKS FOR THE TIP
Old Jun 7, 2009 | 01:16 PM
jschindler's Avatar
jschindler
I just discovered the exact same thing on the hood of my CTS yesterday (it's Crystal Red). I had three coasts of Zaino on it, BTW.
I spent 30 minutes yesterday with a couple of fairly mild to medium mild compounds. I got most of it out - although I can still see it if I look close at the right angle. BTW, clay bar did nothing to get rid of it.
I'm going to let is sit a few weeks and hit it again if it doesn't go away on it's own.
Frustrating!
Old Jun 7, 2009 | 03:33 PM
saplumr's Avatar
saplumr
Frustrating!
It won't go away on it's own. I just had to buff out my daughters Saturn Vue with carbon metallic paint using 3M #05996 Perfect-it foam polishing compound and matching gray foam pad. This is non-abrasive and will clear up the "shadow" or dull area. I thought for sure the bird crap had penetrated the clear but it cleaned right up.
Old Jun 7, 2009 | 04:25 PM
yello9's Avatar
yello9
Originally Posted by gresch
Have you tried rubbing alcohol? I've used it to get bird crap and tree sap off of a few cars. Can't hurt to give it a shot. Then wax the area.
I have heard that what we commonly call tree sap is actually bug poop. Think about it.
Old Jun 7, 2009 | 04:39 PM
Rich Farr's Avatar
Rich Farr
Default Thanks for the advice
I really appreciate the additional suggestions. I have never had this problem before. Previously used liquid glass on 2000 Mag Red C5 as well. Very disturbed by reply about Crystal Red CTS and bird dropping marks as I have 2008 Crystal Red CTS as my daily driver. I am going to try:
1. 50% vinegar solution
2. rubbing alcohol
Will post results.
Regards,
Rich
Old Jun 7, 2009 | 05:54 PM
jschindler's Avatar
jschindler
Sometimes yes, sometimes no. I can assure you I worked on mine with a claybar several times yesterday and it had zero effect. If the clearcoat is truly etched, a claybar will do nothing for that.
Old Jun 7, 2009 | 08:56 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
Originally Posted by saplumr
Buffer and 3M products time.
Old Jun 7, 2009 | 09:28 PM
Rich Farr's Avatar
Rich Farr
Default Progress Report
Spots appear to be fading except for a very large one on fender. I tried vinegar and rubbing alcohol without any result. I am going to leave the spots for a week to see what happens.
Thanks everyone
