Clay Bar Advice?
Old Jun 8, 2009 | 12:48 PM
V RED 08's Avatar
V RED 08
Default Clay Bar Advice?
Is it ok to use Clay Bar on Polished Wheels?
Old Jun 8, 2009 | 01:14 PM
Xedes's Avatar
Xedes
Are they polished w/clearcoat?
Old Jun 8, 2009 | 01:58 PM
V RED 08's Avatar
V RED 08
O.E.M. Polished Wheels. Not sure about clear coat. Can the Bar be used if they are not clear coat?
Old Jun 8, 2009 | 03:01 PM
C8-Vette's Avatar
C8-Vette
Your almost polished wheels have the same clear coat finish as you car. It's OK to use clay bar.As other have suggested it's always better to wash the wheels before using the clay bar.
Old Jun 8, 2009 | 03:10 PM
JJC5's Avatar
JJC5
I suggest making sure that you have all of the brake dust removed from the wheel first because it is very abrasive. The brake dust will stick to the clay bar and abrade the clear coat on the wheels.
Old Jun 8, 2009 | 03:43 PM
easyrider13's Avatar
easyrider13
Use an old clay bar or one you don't intend to use on your car's body.
It's likely that you will pick up some brake dust, even if your wheels look clean.
Old Jun 8, 2009 | 03:46 PM
Grzldvt1's Avatar
Grzldvt1
You will still have some brake dust even after a good scrubbing. Just keep kneading the bar. Then toss the clay bar out as it will be useless for anything else
To Clay Bar Advice?
By Michael S. Palmer | 2026-06-03 09:39:05
