Is This Good?
Old Jun 9, 2009 | 06:42 PM
TBonez's Avatar
TBonez
2005 Beast
Default Is This Good?
Guys,
I don't know a ton about parts etc and wanted your opinion on this mod - is this good?
Custom Grind Camshaft (580 intake, 225 duration, 590 exhaust,229 duration, 114 lobe seperation)
.650 Lift Duel Springs w/Titanium Retainers
New Valve Seals and Keepers
7.400 Hardened Pushrods
New Cryogenic Timing Chain
Oil Pump Is Rework For Higher Pressure
New Timing Cover Gasket and Seal
Amsoil Oil Change w/Filter
New Coolant and A/C Refrigerant
New Harmonic Balancer Bolt
160 Deg Low Thermostat
PCM Performance Tune w/Read Out Springs w/Titanium Retainers
New head gaskets
Ported Intake and TB
Thanks!
Old Jun 9, 2009 | 07:19 PM
dvilin's Avatar
dvilin
I would post your question in the Tech and Performance section where you will get a better response. Just a suggestion.
Old Jun 9, 2009 | 07:57 PM
TBonez's Avatar
TBonez
2005 Beast
Thanks your probably right...will do, appreciate it.
Old Jun 9, 2009 | 07:59 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I would also say, based on your fellow Floridian who had issues with his engine rebuild, you make sure this is a great, great reputation company that's going to do the work. To my knowledge, the original poster of that thread didn't want to impugn the rep, so far, of a forum vendor and asked to have the thread removed!
Old Jun 9, 2009 | 09:20 PM
TBonez's Avatar
TBonez
2005 Beast
I already had the work done, it runs like crazy... the place was extremely good and would recommend to anyone.
Old Jun 9, 2009 | 09:24 PM
danl72's Avatar
danl72
Got numbers? HP, etc
Old Jun 9, 2009 | 09:36 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Well, say hey then! Good going.
Old Jun 9, 2009 | 09:53 PM
TBonez's Avatar
TBonez
2005 Beast
Originally Posted by danl72
got numbers? Hp, etc
440 rwhp
Old Jun 9, 2009 | 09:56 PM
CMY SIX's Avatar
CMY SIX
oil pressure means very little, it's volume that counts, and before you engineers chime in, a modern 12 liter diesel runs about 30 psi all the time idle or wide open, less pressure, less leaks
To Is This Good?
