Wet Windows
Old Jun 16, 2009 | 11:46 AM
stoessjc's Avatar
stoessjc
Default Wet Windows
When I wash my 08 C6 coupe, completely dry it, then lower windows, when I raise the windows they are covered with water on the outside surface. Is this normal? I have never had the door panel off or any work done on the doors.
John
Old Jun 16, 2009 | 12:29 PM
azc62006's Avatar
azc62006
Default water
everycar is like that!
Old Jun 16, 2009 | 12:31 PM
1FUNC5's Avatar
1FUNC5
the rubber sweepers at the the bottom of the window take a while to dry
Old Jun 16, 2009 | 12:33 PM
azc62006's Avatar
azc62006
Default water
the felt seal on the outside get wet when you wash it.. its soaked after you clean your car. you could stop this by not lowering your windows for a bit to let the seal dry?
Old Jun 16, 2009 | 02:16 PM
SonOfDreams's Avatar
0SonOfDreams
Former Vendor
St. Jude Donor '09
Only one fix for it CLICK TO THE ANSWER
Old Jun 16, 2009 | 02:28 PM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I have tried the short drive down the freeway method, but it seems to blow water spots on the areas I just cleaned.
Old Jun 16, 2009 | 02:41 PM
CudjoeScott's Avatar
CudjoeScott
St. Jude Donor '09-'10-'11-'12
John
The easiest way to avoid getting the windows wet, is to lower them all the way, then wash the car.
Old Jun 16, 2009 | 02:45 PM
SanDiegoBert's Avatar
SanDiegoBert
Nah, they still get wet when you roll them up . . . Plus, the sill gets when when you open the door to let the water out.
Old Jun 16, 2009 | 03:25 PM
degaux's Avatar
degaux
... I just fire up the AC and give 'em time to dry...
Old Jun 16, 2009 | 03:28 PM
0SonOfDreams
Former Vendor
St. Jude Donor '09
Confused on this one, the wet felt is on the outside part of the window
Old Jun 16, 2009 | 05:16 PM
dvilin's Avatar
dvilin
Old Jun 16, 2009 | 05:24 PM
calemasters's Avatar
calemasters
It is kind of like getting out of the swimming pool and drying off with a towel. Your swim trunks are still wet for a while.
Old Jun 16, 2009 | 05:32 PM
BigJoe's Avatar
BigJoe
Instead of opening the windows to cool off he should have used the AC, giving it time to dry out... At least I assume that is what he meant.
Old Jun 17, 2009 | 03:34 PM
stoessjc's Avatar
stoessjc
I have the Master Blaster and use it to dry the car. Still have this problem.
Old Jun 17, 2009 | 03:57 PM
0SonOfDreams
Former Vendor
St. Jude Donor '09
You have to point the nozzle into the felt seal and dry the felt with the window down, not just blow out the water but spend 5 min to dry the felt
Old Jun 17, 2009 | 05:11 PM
budgreen3564's Avatar
budgreen3564
Old Jun 18, 2009 | 12:00 AM
TxC5Vette's Avatar
TxC5Vette
Solution: Dry Cleaning
Old Jun 18, 2009 | 12:25 AM
WMark's Avatar
WMark
St. Jude Donor '11
It happens with every car I've ever owned.
I use my compressor to really blow out the water. With my vert, I even blow out the water that catches around the top of the side windows (and the side marker lights, and the tail-lights, and the mirrors, and the emblems, and the list goes on!) Thank goodness these things aren't made out of metal. Water collects in all kinds of interesting body panels! At least enough to ruin a good detailing job if you aren't observant.
Even with that, if I intend to drive the car in the next few hours, some streaking still occurs. MF towels in the trunk, with your favorite glass cleaner clears that up.
To Wet Windows
