c6 problem
Old Jun 27, 2009 | 08:44 AM
BELAL's Avatar
BELAL
4th Gear
Default c6 problem
Hi Guys
I have corvette c6 2009, Its done 2800 KM.
some times I drive it slowly (between 0 - 40 KM) for 30 min or more
The oil Engine and gear temp comes hot (100 C)
when i but the gear from (D) to (N) or from (N) to (D)
the RPM come down to 300 or 200 RPM i feel the car is shocking
and will will turn off also when i press the pedal slowly aftr but the gear in D
then the car goes back to normal...
I will take the car to dealer
but I want to know if this is big or small problem
Old Jun 27, 2009 | 09:01 AM
calemasters's Avatar
calemasters
The text size is a big problem.
100º C for the engine oil and engine coolant temperature is very normal. There is not enough information to diagnoise your concern.
Old Jun 27, 2009 | 09:05 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Could you please try a smaller font
100 C is a normal temperature. What temperature were you expecting to see?
Old Jun 27, 2009 | 09:53 AM
glacierbay2's Avatar
glacierbay2
Hey Belal! It's like you're yelling at us with that font! Do you wear a hearing aid? My car commonly runs 196-212 degrees. And does your car drop to 200-300 RPM, or does it drop by 200-300 RPM? And I think the term you are looking for is "stalling" (not "shocking"). Good luck with the car.
Old Jun 27, 2009 | 12:00 PM
dvilin's Avatar
dvilin
All sounds normal to me, enjoy the car.
Old Jun 27, 2009 | 02:26 PM
BELAL's Avatar
BELAL
4th Gear
Default Ok sorry guys
The Engine oil, gear oil temp be (100 ºC)
I know its normal temp <<< and its not proplem i know that
the problem is
the RPM (dosnt stay in 600 or 700 RPM the normal)Its come down to 300 or 200 RPM i feel the car is shocking
and what is the wrong
Old Jun 27, 2009 | 02:38 PM
VET4LES's Avatar
VET4LES
200 to 300 rpm is a problem and could be caused by many things. A trip to the dealer is a good idea.
Old Jun 27, 2009 | 02:44 PM
HoosVette's Avatar
HoosVette
The oil temperature is not a problem, but the problems you're having when putting the car into gear sounds like you should get it looked at by a dealer.
Old Jun 27, 2009 | 04:02 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Old Jun 28, 2009 | 03:21 AM
BELAL's Avatar
BELAL
4th Gear
Default :)
Thanks guys
Old Jun 28, 2009 | 08:05 AM
yanniz's Avatar
yanniz
converter needs to be looked at in m opinion...
To c6 problem
