Rear End Chatter Thread again....
Old Jul 2, 2009 | 11:46 AM
beav626's Avatar
beav626
Default Rear End Chatter Thread again....
I have an 08 A6. I haven't heard of the 08 or auto cars making this noise.
But I noticed while turning left I heard a chatter from the rear end. I did the search and only found peeps with 07 and older cars having this issue.
Could it be the clutch packs or something else?
Old Jul 2, 2009 | 11:49 AM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
All the threads and available info regarding rear end noise and yet somehow yours is unique?
Change the rear diff fluid under warranty (complain about the noise, don't tell them to change the fluid) like every thread recommends, or do it yourself with all the info that is available in the dozen other threads.
Old Jul 2, 2009 | 11:54 AM
danl72's Avatar
danl72
You may need to take it to your dealer and have them change the fluid. Or you can do it yourself.
Old Jul 2, 2009 | 12:00 PM
Racer86's Avatar
Racer86
My late production 08 made noise starting at 6000 miles. It was supposed to have had the "new " lube in it from the factory. Not a big deal,,, just changed to Amsoil with extra additive. Seems to have worked wonders.
Old Jul 2, 2009 | 12:03 PM
lander's Avatar
lander
No! It changed your lovely Corvette into some ghastly open seat rain catcher!
Old Jul 2, 2009 | 12:54 PM
GOLD72's Avatar
GOLD72
My late production 08 made noise starting at 6000 miles. It was supposed to have had the "new " lube in it from the factory. .......
The factory changeover to DEXRON LS fluid was to begin with MY2009 production. I have never heard whether or not BG changed over earlier near the end of MY2008 production. My son has also a late model 08 built at the end of April. It also has about 6000 miles but he has not mentioned any extra noise yet.
I changed to AMSOIL Severe Gear over 16k miles ago and still quiet.
Old Jul 2, 2009 | 01:01 PM
JRHAWK9's Avatar
JRHAWK9
I changed my '08 out to RP Max Gear, as it already has the additive in it I never had chatter though, even before I changed it out. Although I only had something like 1,500 miles on it when I dumped both the rear end fluid and tranny fluid.
Old Jul 2, 2009 | 01:07 PM
Harry2's Avatar
Harry2
My 2006 A6 had the problem, so far, my 2008 A6 built on October 2, 2007 does not. If it happens again, the dealer will fix it!
Old Jul 2, 2009 | 01:18 PM
RAT's Avatar
RAT
Who cares if it's been posted before. If he wants to ask a question here on the forum then no biggie. Yes, his car is unique if you have to ask. It's his, and I'm sure it's his baby.
It's under warranty I'm assuming. I would take it to the dealer you bought it from and have them check it out. If not, changing out the fluid is a 30 minute job at max.
Old Jul 2, 2009 | 01:23 PM
lander's Avatar
lander
Maybe those of us that like to help those with problems that attempt to help themselves first. So when people decide to post the same question for the umpteenth time because it's easier than searching...yeah, I have a problem with that. Now run along
Old Jul 2, 2009 | 01:25 PM
04_Z06_CE's Avatar
04_Z06_CE
Whats funny is he actually took the time to write the hating ...
Old Jul 2, 2009 | 01:31 PM
lander's Avatar
lander
What's even funnier is the ignorance of those that think that, considering I answered his question along with pointing out he could have found the answer with a simple search.
Big difference...but I don't expect the intellectually challenged among us to distinguish the difference.
Old Jul 2, 2009 | 01:44 PM
RAT's Avatar
RAT
You're are a class act. If you can't contribute to his thread in an adult manner. Stay out of it.
Old Jul 2, 2009 | 01:52 PM
RedZR's Avatar
RedZR
Is there an acceptable substitute for the GM stuff?
Dan
Old Jul 2, 2009 | 02:13 PM
99ssconv's Avatar
99ssconv
#07-04-20-002A: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid) - (Jan 9, 2008)
Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid)
Models: 2004-2008 Cadillac XLR (Including V-Series and Export)
2005-2008 Chevrolet Corvette (Including Z06 and Export)
This bulletin is being revised to change the fluid recommendation and to remove the requirement of adding friction modifier. Please discard Corporate Bulletin Number 07-04-20-002 (Section 04 -- Driveline/Axle).
Condition
Some customers may comment on a clunk and/or chatter type noise from the rear of the vehicle while making turns.
Cause
This condition may be caused by slip/stick of the posi-traction clutch plates due to insufficient limited-slip axle additive. As plates slip and stick, a jumping or jerking feel occurs accompanied by a clunk noise.
Correction
Important: DO NOT remove the differential cover from the rear or the two sides. It is not necessary to flush the old fluid from the differential.
Drain and refill the rear differential fluid.
•Fill the differential with the new DEXRON® LS gear oil, P/N 88862624
Old Jul 2, 2009 | 02:39 PM
beav626's Avatar
beav626
If you read the original post I mentioned that I did a search and found nothing pertaining to cars newer than a 08 or Automatic.
Condition
Cause
Correction
This is what I was looking for-Thank you and those that were able to contribute to this.
Old Jul 2, 2009 | 03:08 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
PM sent.
To Rear End Chatter Thread again....
Old Jul 4, 2009 | 12:18 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Dan
Dan,
This seems to work very well for a lot of C6 users:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (product code SVGQT)
AMSOIL Slip-Lock Differential Additive (product code ADABA - I recommend one bottle for the C6)
For the DIYer:
AMSOIL Hand Pump (product code G2039)
Note: I recommend taking the plastic tip off the fill hose - not needed and might come off.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 4, 2009 | 12:25 PM
lander's Avatar
lander
Get a dog, kick it, cause you don't stand a chance with me. You have no control of where I do and don't post, sonny boy.
Now, run along and be a man in your world.
Old Jul 4, 2009 | 12:27 PM
lander's Avatar
lander
Originally Posted by Subdriver
Dan,
For the DIYer:
And get it from Subdriver . He had the oil to my doorstep in a couple of days, and the pump worked great for my Explorer (didn't need it for the Vette, but would have been nice. ).
I don't recall a plastic tip on the hose though...
