Oil changes ??
.Anyway the input I got was just change it in another couple thousand miles or so or when you have 5000 miles on the oil life, Okay makes sence
.Now I go to my Chevy dealer to look around the spoke to my service rider who I deal with. I asked him "when was the last time I changed my oil ? " He looked it up and said a 15 months ago therefore you should get it changed either once a year OR 5000 miles. ( Keep in mind I've only driven maybe 3500 miles )
So the question is................ Is that true
or can I wait, and how much longer ? If it matters the car is only driven maybe 100 miles a week.
On the other hand, don't change it tell your ready, it's your car...
Why would anyone want contaminated oil setting in their motor?
And why pay someone to do a task that on the scale of one to ten in difficulty doesn't even rate a one. Oil drain plug - lefty loosey righty tighty. Same for the oil filter and oil fill hole.
And WHY don't owners read the manual? RTFM
I would never go below 10% on the DIC, worst case.
1.) So you just blindly trust everything GM says? Changing your oil at 5k just because GM says so probably has a lot more to do with a dealer making money then it does with contaminated oil. I prefer to use objective test results rather than a bankrupt company for when I should change my oil. Every test I have had done shows that I can go 7500+ with no adverse impact on my engine.
2.) Some people have never worked on a car and while it may seem like a very simple thing to many of us if you have never worked on a car and are not comfortable doing so I'd say they are probably better off leaving it to the pros. What may seem like a difficulty of "1" to you may not be to someone else. Thinking everyone should feel the same way as you do about this is naive at best.
3.) I agree everyone should read their manual but sometimes we humans don't retain 100% of everything we read especially something like an owners manual. That is what is so great about the forum. You SHOULD be able to ask a simple question and get a simple answer.
Peace, out.
BTW, I read the manual...and look at the DIC.
When to Change Engine Oil
Your vehicle has a computer that lets you know when to
change the engine oil and filter. This is based on
engine revolutions and engine temperature, and not on
mileage. Based on driving conditions, the mileage at
which an oil change will be indicated can vary
considerably. For the oil life system to work properly,
you must reset the system every time the oil is changed.
Z06 models have a racetrack-ready dry sump engine
lubrication system. This high-performance system
operates differently than a standard engine lubrication
system and requires a special procedure when changing
the engine oil and filter. See Engine Oil on page 5-17.
When the system has calculated that oil life has
been diminished, it will indicate that an oil change is
necessary. A CHANGE ENGINE OIL message will come
on. Change the oil as soon as possible within the
next 600 miles (1 000 km). It is possible that, if you are
driving under the best conditions, the oil life system
might not indicate that an oil change is necessary for
over a year. However, the engine oil and filter must
be changed at least once a year and at this time
the system must be reset. Your dealer/retailer has
trained service people who will perform this work using
genuine parts and reset the system. It is also important
to check the oil regularly and keep it at the proper
level.
If the system is ever reset accidentally, you must
change the oil at 3,000 miles (5 000 km) since your last
oil change. Remember to reset the oil life system
whenever the oil is changed.
5-23
One sensor it reads is the oil %.
When, from one month to the next month, the oil % changes to a higher number, Onstar assumes the indicator has been reset, and the oil has been changed. It saves the date it sees such a change.
One year later, if the oil % indicater has not been reset, it will remind you in the monthly email that the oil needs to be changed, no matter what the current Oil % is.
Read the manual. It says the oil should be changed at least one a year. And this is what the Onstar email is prompting you about.
