Jack Stand Location
Old Jul 19, 2009 | 09:11 PM
Mu$cle's Avatar
Mu$cle
Default Jack Stand Location
What is the proper location for jack stands on a C6 Z06? I need to have all 4 wheels in the air to remove the rotors to take care of some rotor hub rusting. Any suggestions on how to handle the rotor problem? (engine enamel, ceramic coating, teflon paint)
Old Jul 19, 2009 | 10:08 PM
HANNY's Avatar
HANNY
you can put them under the rear end below the aluminumbracing part and also on the front you will see a similiar spot below aluminum bracing. I have used those spots (dont know if i explained it very well) for the stands but jack at the 4 points made for that. good luck paul
