Very easy DIY install/swap. Z51 bars unless you go to the Z06 size wheels and tires then the Z06 bars. And you need both. You have base suspension, right?
yes base susp
in the future i do want wider wheels, so better z06 sways
NO, wait till you get the bigger wheels. The Z06 rear bar will give you unsafe over steer with the standard wheels/tires. I think you will be happy with the Z51 bars even with larger wheels/tires but at least start there then decide later.
Great mod...big difference in the way the car drives. Don't do the Z06 bars, do the Z51. Then replace the shocks with Bilsteins for $300 and you will be amazed!
I installed the Z51 sway bars and I could tell the difference.
