Check Engine Light - CAGS?
Old Jul 26, 2009 | 08:18 PM
tomzarbo's Avatar
tomzarbo
Default Check Engine Light - CAGS?
I have had my blown littelfuse Smartfuse in my '06 Vette for a few months with no problems.
A few days ago, the check engine light came on, I scanned it with my OBD2 reader, and it said that the problem was with the skip shift, I forget the code number. I didn't realize that an issue with this caused the check engine light to illuminate?
I cleared that code, and drove for a few more days, now it's on again.
I guess the fuse could be toast. It says on the package that the light should be on if it is blown -- but the ignition should be "on". How do you do that in a Vette? Isn't it either running or in acc. mode? Just check it while it's running I guess? So if it isn't lit up, then I guess it's bad. Oh well, they came two to a pack!
Has anyone had a similar issue?
Thanks,
TomasZ
