Power Wash Engine
Old Jul 30, 2009 | 12:32 AM
Torch Ace's Avatar
Torch Ace
Default Power Wash Engine
Has anyone out there power washed their engine or engine compartment - C6/LS2 ? Any problems or watch out for's?
Old Jul 30, 2009 | 12:45 AM
cranky's Avatar
cranky
yes i have, several times. be sure and take a plastic bag and completely cover the fuse block. do not spend time on any of the connections. leave the fuel rail covers on. stay away from any intake air filters.
Old Jul 30, 2009 | 12:49 AM
VettedCandidate's Avatar
VettedCandidate
Yes....no.
Old Jul 30, 2009 | 01:02 AM
bterwilliger's Avatar
bterwilliger
Never powerwashed, but gently hosed off. I would suggest a bag over the alternator too.
Old Jul 30, 2009 | 01:05 AM
VettedCandidate
I've never had a problem with hose washing.
Old Jul 30, 2009 | 02:18 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Hose washed on my 08 LS3 with no problems. I let air dry for 1 hour after just to be safe.
Old Jul 30, 2009 | 03:04 AM
spin-doktor's Avatar
spin-doktor
a million times noooooooooooo
Washing the engine bay as suggested above can potentially cause the alternator housing and alternator bracket and other metal surfaces to change in appearance.
Use a damp microfiber and wipe the dust/dirt off. You will achieve better results without having to get EVERYTHING wet.
Hose washed = used hard water. Let air dry = hard water spots etched everywhere. ( frame rails, plastics, etc)
Old Jul 30, 2009 | 03:09 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
With all the electronics under the hood...it's a BAD idea to add water. However, my alternator and bracket has turned very dull and has white spots all over. My engine compartment has NEVER been wet. I plan on taking the bracket and alternator off and painting them.
Old Jul 30, 2009 | 03:16 AM
spin-doktor
Originally Posted by obxchartercaptain
... my alternator and bracket has turned very dull and has white spots all over... ...I plan on taking the bracket and alternator off and painting them.
Yes. The alternator and the alternator bracket will get dull and develop a type of aluminum "oxidation" that looks like little white spots all over. No BS.
Old Jul 30, 2009 | 04:46 AM
User 81424's Avatar
User 81424
I use a lite mist, then start the engine.
Old Jul 30, 2009 | 06:42 AM
Nate's first vette's Avatar
Nate's first vette
I left the engine running while I washed it down with a water hose. Light presure. I once had a jeep cherokee that wouldnt start for two days due to presure washing.
Old Jul 30, 2009 | 06:46 AM
Patman's Avatar
Patman
I used Spray Nine and a garden hose on light pressure to wash the engine in my C5 this week, and was careful to avoid the alternator. But now I've got something squeaking under the hood I just hope it goes away this time (I got squeaking before when using the underbody spray at the car wash last winter but it slowly went away after about 100 miles of driving)
Old Jul 30, 2009 | 07:22 AM
thechief's Avatar
thechief
I have never powerwashed a motor. But I have used a hose with success and no issues. I use Simple Green on a warm motor and let it soak for a few minutes. Then I simply hose it off with a gentle flow of water.
Next I shoot the area with Armor All and start up the motor and let it dry. Never had any water spots. Looks great.
When I do the 6 I will cover the alternator and fuse box.
Old Jul 30, 2009 | 07:46 AM
VettedCandidate
OK, this is where you have to ask yourself how **** you are or want to be about your car.
I have carefully washed (sometimes with high-pressure carwash wands) the engine compartment of every one of my cars (including my '05 LS2) and have NEVER had any problem. However, I am not examining every part of my car to see the visual effect of doing this.
If you will never drive your car in the rain, don't wash it. If you are using it as a show car, don't wash it. Just get in there when it is brand new from the factory and make sure you do numerous layers of Zaino, Rejex, paint or whatever and dust thereafter.
I'm not one of those people but certainly respect those who are.
Old Jul 30, 2009 | 07:58 AM
vettenut's Avatar
vettenut
KY Events Coordinator
Default Engine clean
I use S100 available in most motorcycle shops.
1. Spray everyjing under the hood.
2. After a few minutes, hose it off.
3. Walk away for 30 minutes.
4. Return & be amazed
Old Jul 30, 2009 | 08:07 AM
jschindler's Avatar
jschindler
Too many electronic connections. Just take damp rag and compressed air to it for a few minutes every few weeks and you'll never have to risk any problems.
Old Jul 30, 2009 | 08:22 AM
cthusker's Avatar
cthusker
Just because the car starts doesn't mean corrosion hasn't been introduced into many electrical connections. They are NOT watertight in many cases and once the process starts it can cause problems later on. Not something I'd do unless it was absolutely necessary (ie: oil line break) and you had a lot of cleaning to do.
To Power Wash Engine
Old Jul 30, 2009 | 08:28 AM
thechief's Avatar
thechief
I have to reply again. Cars are made to withstand water in moderation. If you drive it in the rain it will get moisture under the hood. The car will survive. To think that water will deadline your your car when used carefully is an overreaction. We are not dealing with 1970's vintage Detroit crap.
Old Jul 30, 2009 | 08:30 AM
Patman's Avatar
Patman
But when you drive it in the rain the water is splashing on the underside of the engine, and if you pop the hood you'll find that the upper section (where most of the electrical connections are) is still bone dry.
Spraying water directly onto those connections from above introduces a ton of water onto them, but driving in the rain does not.
Old Jul 30, 2009 | 08:40 AM
DeeDubya's Avatar
DeeDubya
I have used a pressure washer many times without a problem. I do however keep the nozzle some distance away so as to not force water into places it shouldn't go.
Also, I like to drive some after washing the engine bay so that the heat will help it dry completely.
Hose washing is probably the safe way to go.
