As was previously stated...hockey pucks work great...for an added extra, drill a small hole in the middle of each one and put a threaded eye bolt in (with super glue), then screw the eye bolt into the puck. That way, the puck will not fall out of the car.
The eyebolt is especially helpful for making sure the puck is lined-up and properly seated. A mis-aligned puck might allow damage.
And be sure to remove the puck when you're done. The eyebolt does not securely attach the puck to the rocker panel.
Oh, and get an extra set of pucks (8 total). That's because you might (just possibly) need 2 pucks per jacking point. Depends on your jack or jack stands. Anyway, cheap insurance for just a couple of bucks.
