Old Mar 25, 2015, 01:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
C6 Ashtray door
Old Aug 4, 2009 | 10:36 PM
blackmagic9805's Avatar
blackmagic9805
Default C6 Ashtray door
I have a C6 ash tray door that won't stay closed. Is there a quick fix or must it be replaced?
Old Aug 4, 2009 | 10:38 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I took mine in 3 times and was replaced twice. Stays shut after replacement the 2nd time... take it in get it replaced....
David
Old Aug 4, 2009 | 11:00 PM
Wizekrakr's Avatar
Wizekrakr
Quick Fix? Super glue!!! Thats probably not the answer you wanted. I would have to take it in to get it fixed.
Old Aug 4, 2009 | 11:08 PM
danl72's Avatar
danl72
Dealer visit.
Old Aug 4, 2009 | 11:14 PM
blackmagic9805
Default C6 ashtray door
Thanks for the replies. Any idea of the dealer charge to repair? The thought of super glue might make sense. Just kidding.
Old Aug 4, 2009 | 11:56 PM
06 C6 vert's Avatar
06 C6 vert
Had mine done once on warranty to no avail. I gave up. I leave mine open, Hey its a Chevy, but one hell of of a Chevy.
Old Aug 5, 2009 | 12:02 AM
Zymurgy's Avatar
Zymurgy
Moderator
Here is a DIY repair post: http://forums.corvetteforum.com/1556451070-post1.html.
All kinds of great things on this forum if you'll spend some time using the search capabilities.
Old Aug 5, 2009 | 12:07 AM
06 C6 vert's Avatar
06 C6 vert
You have much to much time on your hands............
Old Aug 5, 2009 | 12:12 AM
Vette_DD's Avatar
Vette_DD
Because proper use of the search function gives you that extra time.
Zymurgy's Avatar
Zymurgy
Moderator
Took me about 30 seconds to find it.
Old Aug 8, 2009 | 11:17 AM
teckguy's Avatar
teckguy
Default Fix
Another trick I found was to take it apart and bend the spring slightly so it has slightly less tension on it. The door falls a bit more slowly but it does come down completely and stays shut when not in use!
Old Aug 8, 2009 | 08:08 PM
blackmagic9805
techguy:
Is it difficult to remove the bezel trim and ashtray assembly to reach the spring. I also think I found a replacement for $40.00 I can just replace the faulty unit. Is it a difficult removal?
Old Aug 8, 2009 | 08:09 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
Gorilla super glue..... LOL
Old Aug 8, 2009 | 08:26 PM
teckguy's Avatar
teckguy
Default Fix
5 minute job, remove the door by starting on the right side with a flat screw driver:
Once the door is out remove the components attached to inside of the door unit. You will find an ash tray & ash tray holder. Adjust spring tension then re-install only the door and check for opening and movement. When you are happy with door operation only then insert the (ash tray holder) & (ash tray) itself. Job done! The spring re-installation and adjustment is quite easy to do with the holder and tray NOT installed!!!
Old Aug 8, 2009 | 08:38 PM
06 C6 vert's Avatar
06 C6 vert
What if you just take the spring off?
Old Aug 8, 2009 | 08:47 PM
teckguy's Avatar
teckguy
Default Spring Off
Then the door is hard to open and rather junky feeling. Just bend it a bit, less tension is the trick.
Old Aug 8, 2009 | 09:10 PM
MurphMan2's Avatar
MurphMan2
It's an open forum just like all the other forums and the same questions get asked time and again. Not a bad thing as it keeps popular topics in front of the eyes of everyone.
To C6 Ashtray door
Old Aug 8, 2009 | 09:52 PM
CMY SIX's Avatar
CMY SIX
mine won't eitheir!!!! had the dealer replace and it still won't!!!!!!
Old Aug 9, 2009 | 01:09 AM
Always Red Dave's Avatar
Always Red Dave
Replaced mine it wasnt much money for the ashtray forget the price now it works fine I dont smoke so I just leave it shut all the time good luck with your fix.
Old Aug 9, 2009 | 01:15 AM
keyplyr's Avatar
keyplyr
This is an open and shut case.
