Meguiars Swirl X
Old Aug 6, 2009 | 05:41 AM
bigterpsfan's Avatar
bigterpsfan
Default Meguiars Swirl X
It appears that when at a car show, someone rubbed up against my black ZO6, and left very very light scratches. They are so light that you can only see them in sunlight and not in the shade. I was wondering if Mequiars Swirl X would help out with something like that? I was planning on trying it in that section and then waxing over it with Mequiars NXT 2.0 to make sure that there is a layer of protection there afterward. First, is the product safe to use on the car and will it help out? Thanks!
Old Aug 6, 2009 | 06:13 AM
bksnoopy's Avatar
bksnoopy
Their product states:
"Meguiars Swirl X Swirl Remover is an ideal product for anyone whose vehicle is suffering from micro-fine swirls. It requires no special equipment – just apply by hand to rid your vehicle of unsightly swirls and restore a smooth, reflective finish. The nonabrasive formula will not contribute to new swirls as it smoothes away micro-fine spiderwebs. Meguiars Swirl X Swirl Remover is designed to give you quick, dependable results by hand or DA polisher".
I use NXT 2.0 In my opinion it is very easy to use and does a great job.
Here you can see my junk in the reflection.
Ben, OH
Old Aug 6, 2009 | 06:29 AM
Scruff Vette's Avatar
Scruff Vette
I would give it a try. I have used Scratch-X with mixed results. I all depends on how you define "micro-fine swirls". GM clearcoat is hard and difficult to polish out.
Old Aug 6, 2009 | 07:34 AM
09C6Coupe's Avatar
09C6Coupe
Menzerna SIP or Menzerna Final Finish will take out the worst of scratches.
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I've had better luck with 3M microfinishing compound.
Old Aug 6, 2009 | 07:35 AM
DSOMvette's Avatar
DSOMvette
St. Jude Donor '09
mixed results also.
Old Aug 6, 2009 | 07:36 AM
bigterpsfan
Do you leave it on and let it dry or apply and wipe off immediatley? I haven't bought a bottle yet so I don't have the directions.
Old Aug 6, 2009 | 08:01 AM
Scruff Vette
Work it over the surface it on using a foam applicator. Don't press too hard. Let the polish do the work. Wipe off with microfiber towel. After one or two tries you'll see if it's being effective or not. If it doesn't appear to be working, DO NOT press and rub harder, you'll only create more scratches. Don't ask how I know. Good luck.
Old Aug 6, 2009 | 08:11 AM
not08crmanymore's Avatar
not08crmanymore
Who sells this stuff?
Old Aug 6, 2009 | 08:54 AM
Patman's Avatar
Patman
Swirl X is a very light formula which might not be enough to remove the swirls on the hard clearcoat of the Corvette. I've had excellent results using Meguiar's slightly stronger Scratch X 2.0, with just one pass using that stuff with my UDM polisher (similar to Porter Cable) it got rid of quite a lot of the minor swirls and light scratches in my black paint. And then when I topped it off with NXT 2.0, that also helped to hide some more of the remaining flaws too. Most people that see my car comment on the fact that they can't believe how good my black paint looks for a 12 year old car with 106,000 miles on it. Now you know my secret!
Old Aug 6, 2009 | 09:08 AM
New York Black C-6's Avatar
New York Black C-6
I have used this product with mixed results on black. I was not happy and it seemed I created more small scratches by using this product.....after using it I took it to a friend of mine that buffed the entire car and it looked like new money (At least for a week)!
Old Aug 6, 2009 | 09:33 AM
bigterpsfan
Do I need to use a polisher, or can I just use the applicator pad?
Old Aug 6, 2009 | 09:40 AM
TBIRD57's Avatar
TBIRD57
Default well?
e-mail me if you get an answer.
Old Aug 6, 2009 | 10:04 AM
Patman's Avatar
Patman
You can use the applicator pad, but it'll take you a lot longer to do larger sections and you won't get as effective results as you would with a dual action polisher.
Old Aug 6, 2009 | 10:30 AM
Hatchet's Avatar
Hatchet
Scared me for a second when I first read that...
Old Aug 6, 2009 | 10:49 AM
JDC1999's Avatar
JDC1999
Old Aug 6, 2009 | 10:53 AM
GotVett?'s Avatar
GotVett?
Thanks for the heads up.
To Meguiars Swirl X
Old Aug 6, 2009 | 10:58 AM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
ive had excellent results with Zaino's Fusion (you knew this was coming.... )
Old Aug 6, 2009 | 11:04 AM
greengo's Avatar
greengo
Wolfdog is the Zaino god!
Im waiting to one day read a post from him telling me how to use it on toast for breakfast!
Im sure it would be fantastic too!
Old Aug 6, 2009 | 12:29 PM
smbsocal's Avatar
smbsocal
I have used Meguiars Swirl X on my red Jeep Commander but not my Vette yet. The Jeep had a number of swirl marks and deeper scratches. It was able to remove all of them and did a good enough job that I didn't have to follow up with a finishing polish. I am not as **** with the Jeep as I would be with the Vette though.
