Anybody know the GM part number for the door panel trim insert plugs in each color for the C6? They are a couple inches long and and oval shapped and snap into the door. I can't find the numbers anywhere and I've been searching for ever! If you can provide me the correct part numbers I will paypal you $10 lol!
Email Gene Culley. Gene has always found the part number for me. I usually email him saying "I need the small thingy that connects xxx" and he always finds it for me. Gene is THE MAN!
The part you are describing sounds more to me like a C5 part than a C6 part. The C6 door doesn't have that same trim panel.
What about the cashmere and gray part numbers? Are there any other factory door colors for C6's or just those cashmere, gray, and ebony? BlackZ51Vett's picture shows the plug I'm talking about. BlackZ51 can you pm me your email so I can paypal you $5 since you gave me one number. I'll still give $5 for each additional color part number. Thanks guys!
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Originally Posted by joshisurdaddy
BlackZ51 you are the MAN!
Anyone else have the other colors?
I have only seen these in black and have painted mine to match different interiors. Also I believe the plug is the same as the C5 plug so checking in the C5 section may yield some more results.
LOL. I got a kick out of this. I'd be happy to help or order one! Thanks for the referral.
Probably replaced because once you remove the cover the edges of the retaining tabs get bent and the tabs don't hold correctly when you try to install the cover again.
