Front Caliper Torque
Go to forum member David Farmer's excellent website for all your torque specs:
http://davidfarmerstuff.com
Edited: I just looked at David's torque specs for the C6. The spec I listed above is for my C6 Z06, but he has 125 ft-lbs listed for a C6. I think that is out of the 2005 manual - I think GM changed the spec to 129 for all models of the C6 in 2006. However.....4 ft-lbs in that range of torque is a very small amount and probably doesn't matter much. I'd recommend 129 for all caliper bolts.
Bob
Fastener Tightening Specifications
Application
Specification
Metric
English
Brake Caliper Bleed Screw
12 N·m
106 lb in
Brake Caliper Brake Pipe Fitting (J56)
40 N·m
30 lb ft
Brake Caliper Guide Pin Bolt (JL9, J55)
31 N·m
23 lb ft
Brake Caliper Inlet Fitting Bolt
45 N·m
33 lb ft
Disc Brake Pad Pin (J56)
40 N·m
30 lb ft
Front Brake Caliper Bolt (J56)
175 N·m
129 lb ft
Front Brake Caliper Bracket Bolt (JL9, J55)
175 N·m
129 lb ft
Rear Brake Caliper Bolt (J56)
175 N·m
129 lb ft
Rear Brake Caliper Bracket Bolt (JL9, J55)
175 N·m
129 lb ft
