Stuck in Neutral
Old Aug 9, 2009 | 09:42 PM
ssrvette's Avatar
ssrvette
Default Stuck in Neutral
Help, I'm stuck 90 miles from home, and the vette will not shift into park. the car won't start, any suggestions. It ran great, then I parked it, went to move, got it into D, now can't get it into any other gear...... the accessories have been on and now it killed the battery.... yes it is an automatic......my wifes vette....... darn
Old Aug 9, 2009 | 09:54 PM
VettedCandidate's Avatar
VettedCandidate
Turn the steering wheel and giggle the shifter. Then try to start and shift.
Old Aug 9, 2009 | 10:05 PM
not08crmanymore's Avatar
not08crmanymore
Read the manual.There's a section on this.Sounds like the shift lock over ride is shot.There's a switch or something behind the brake pedal that's supposed to release the shifter.
Old Aug 9, 2009 | 10:40 PM
crazyfrank's Avatar
crazyfrank
same thing happened to my 2007 coupe. disconnected the battery cuz i couldnt figure it out. towed to dealer. theres a safety switch under the shifter that prevents car starting in gear.they pulled the console, etc out to get to it.fixed under warrenty in less than a hour. hope this works for you
To Stuck in Neutral
