Run flats SUCK
Old Aug 11, 2009 | 02:04 PM
1955 copper's Avatar
1955 copper
2015 C1 of Year
Default Run flats SUCK
Have a 06 C6 and the run flats suck in more ways then others have stated in the past .
First they ride hard and are noisy, Having hard stiff side walls is what makes them run flats but as I found out they will also bend the wheel, three of the four of my GM chrome wheels were bent on my Corvette when I had new Toyo tires put on . I live in left Ca. Where the roads suck having pot holes . The walls of the run flats are so hard that they bend the wheel if you hit a pot hole I found out . The worst was the right front wheel which also caused the tire lining to wear through '
So I was wondering how many other owners have had this happen to them!
By the way the Toyo are 75% quitter and the ride is softer then those shi**ty run flats . If GM offered me FREE run flats for life I would never put them on. Your opinions!!
Old Aug 11, 2009 | 02:14 PM
gatti-man's Avatar
gatti-man
Run flats are a necessary evil unless you have AAA or are friends with a tow truck driver. Flats do happen.
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
at the risk of having my tires chewed off , I disagree. they do ride hard and aren't particularly quiet, but I'm not listening for them, nor do I really care that much if other tires ride better.
that your wheels were bent may or may not be attributed to the tires. it may just be the potholes you went over, and the wheels that you have, with any tire on it. but I wouldn't want you to experiment and find out for sure with another set of wheels and a different set of tires.
Old Aug 11, 2009 | 02:15 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
2001 Coupe: 68,000 miles on GY runflats, no bent wheels.
2006 Coupe: 44,300 miles on GY runflats, no bent wheels.
2009 Coupe: 6,200 miles on GY runflats, no bent wheels.
The 2006 and 2009 have the Supercar runflats, stiffest sidewalls.
This is all on the bombed-out roads of northern Illinois.
Operator technique may be an issue here...
Old Aug 11, 2009 | 02:16 PM
sweitznr's Avatar
sweitznr
You're right of course that the carbon fiber (and otherwise reinforced sidewalls) when combined with a "plus size" wheel over a large disc are a disaster when driven over rough roads. On my daily driver, a big Jag, I have 20 X 9 inch alloys with Goodyear Eagle F1 All Seasons. They aren't even runflats but they are 35 profile and they have the carbon fiber sidewalls. Over the winter I replaced 3 out of 4 wheels. The main problem occurs when the inner rim hits a hole or bump without the support of the outer rim because there's no spokes there to support them. But if the runflat gets you home or to a safe haven after air loss I guess it's worth it. Not much alternative when you don't have a spare.
Old Aug 11, 2009 | 02:18 PM
Vette_DD's Avatar
Vette_DD
I'm crazy about my runflats. I hit potholes twice that severely damaged a runflat when I had my silver 05 C6. Didn't have to stop on the side of the road and replace a flat tire.
Hit an unseen object with the right rear runflat on my 06 C6, same solution. Drove it for a week with a flat tire until the Chevy place could get me a new tire (another runflat).
You no longer have to wait until you're near a phone booth to make a phone call when you're on the road and have your cell phone with you. Why shouldn't your tires also be from the 21st century?
But I understand your situation and you have my sympathies.
EDIT: Forgot to mention the fact that I had no damage to the wheels during any of those 3 damaged tire incidents.
lander's Avatar
lander
St. Jude Donor '09-'10-'11
I think someone needs to take a .
Old Aug 11, 2009 | 02:20 PM
LMB-Z's Avatar
LMB-Z
I traded mine for BFG KD II's. No traction, harsher ride, more noise. Now I can at least hear my exhaust, and can't hardly spin a tire.
Old Aug 11, 2009 | 02:22 PM
VettedCandidate's Avatar
VettedCandidate
I will agree that the standard run flats I got on my '05 vert are noisy and a bit rough but, and I don't know if this is the tires or the F55 suspension, I love the ride and cornering of this car big time and the tires must have something to do with it!!
Old Aug 11, 2009 | 02:33 PM
car2fast4you's Avatar
car2fast4you
My biggest complaint about the run flats is their extremely poor traction in cold weather.
Once it gets below 40, you have to be really careful.
Other than that, they're OK.
Old Aug 11, 2009 | 02:36 PM
gatti-man's Avatar
gatti-man
bottom line the run flats are not a performance tire. I think that is the main criticism. Its a sports car with terrible tires. Not that this is uncommon.
Old Aug 11, 2009 | 02:39 PM
Flat Broke's Avatar
Flat Broke
You sure have a right to be upset over bent rims. However you can bend rims with any tire. I have bent a front tractor rim and did not damaged the tire. I think you are putting the blame in the wrong place. Blame the pot holes.
Old Aug 11, 2009 | 02:53 PM
4CEE's Avatar
4CEE
My gripes are with Firestone. Guess I'll have to start my own thread.
Old Aug 11, 2009 | 03:06 PM
JT Metal's Avatar
JT Metal
St. Jude Donor '12-'13
My biggest compliant about R.F.'s. My wife had asked me to take her on a short trip. Well about 20% on the ride got a flat and the only bitch I had, Was we kept going.......
Old Aug 11, 2009 | 03:16 PM
dvilin's Avatar
dvilin
I can put up with the bit of road noise with RF's given the security they offer. I have not noticed any other significant downside to them.
Old Aug 11, 2009 | 03:31 PM
JFFVETTE's Avatar
JFFVETTE
Maybe it's not the run flats that damaged the rims. Most low profile tires, have the capability to damage the rims, with severe impact due to the small side walls. I've damaged other rims on my cars, and even my truck, when the pot holes were severe enough to allow the rubber to distort and contact the rim.
Old Aug 11, 2009 | 04:28 PM
WAwatchnut's Avatar
WAwatchnut
This really isn't a run flat issue as much as a summer, sticky compound rubber issue. Any of the tires with really soft compounds are going to stiffen up and be pretty much unusable below 40. You'll get the same warnings about cold weather from the mfr's, no matter if it's a run flat or not.
To Run flats SUCK
Old Aug 11, 2009 | 04:29 PM
thechief's Avatar
thechief
I am waiting for mine to wear out so I can get a quieter better riding tire.
I just replaced the RFs on my Lexus GS350 after 50,000 with new ContiTouring and the difference is amazing. The ride is great and quiet. I can hardly wait for the C6 change out.
Old Aug 11, 2009 | 04:39 PM
-CM-'s Avatar
-CM-
Did the tires change for 09? I don't find the tires any noiser than my other vehicles. As for ride comfort, I don't have another Vette to compare to, but I don't notice anything I can attribute to the tires. On a nice road, the ride is nice; on a not-so-nice road, the ride is not-so-nice.
I just had a flat this past weekend. The tire shop took the tire off the rim to patch it, and there was no bent rim issue.
I honestly don't know what all the complaints are about, and I hope it stays that way as the tires age.
Old Aug 11, 2009 | 04:47 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
to your statement.
AND this is why...
http://forums.corvetteforum.com/c6-c...ht=eboggs_jkvl
Elmer
