2005 stalling
Old Aug 12, 2009 | 08:16 AM
Nova Scotia C4's Avatar
Nova Scotia C4
Default 2005 stalling
Hi all:
Usually I hang out in the C4 section but have a question from a buddy here in Nova Scotia. He has a C6 (2005) with approx. 8,000 miles on it, automatic. Says he drives along and the car will stall with no warning. Pulls to the side, puts in neutral or park, pushes ignition button and it starts. Has done this several times and has had it in the shop. Has yet to find a proper answer, stalled while idling in the shop! I told him about this forum and how helpful people are. Hopefully, you can assist this guy. Thanks in advance and "save the wave".
Old Aug 12, 2009 | 11:26 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its really hard to point a direction to look without more information. Such as, are there any DIC warnings when this happens? Are the guages/electrical all still working or dead? Bad gas with water in it? He needs to get a "CAN" enabled code reader and see if there are any codes.
Old Aug 12, 2009 | 12:01 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by Nova Scotia C4
Hi all:
As noted, this will be much easier to diagnose with information about the codes that the car will have stored. If it came on suddenly it could be as simple as bad gasoline but it could also be other problems. Have him scan the codes and post the information here and we can do a much better job of helping identify the problem.
Old Aug 12, 2009 | 12:10 PM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
doe it fire right up after it stalls,,,or doe it spin a bit first?
Old Aug 12, 2009 | 12:15 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Without any other information to work with, sounds like a fuel problem....fuel pump; clogged pickup (unusual if only 8000 miles).....as several others have pointed out, need to see if any codes are being thrown.
Old Aug 12, 2009 | 04:15 PM
Nova Scotia C4
Says it fires right up, but will check with him further.
Bob
Old Aug 13, 2009 | 09:11 PM
kxb144's Avatar
kxb144
bump
Old Aug 14, 2009 | 05:43 PM
kxb144's Avatar
kxb144
Have a fellow here in Windsor that has a 2005 automatic, 14,000 km on it.
>> The problem is: driving along and without any warning the car shuts off!
>> Coasts it to the side of the road, puts it in park or neutral, pushes the
>> start button and it fires right up. Off he goes. Has the car in shop now
>> and they haven't been able to correct the problem. He
>> said it stalled on their floor as it was idling. Don't know if any codes
>> were showing or not, he didn't say. Wondering if anyone in the club has
>> heard of this being a problem or if any C6 owners have experienced it? If
>> you could pass this on for feed back it would be appreciated.
>>This was the l orginal email our corvette club received. hope you can help .Thanks Kevin
Old Aug 14, 2009 | 08:10 PM
dgrant3830's Avatar
dgrant3830
There is a reported problem for several people of a bad electrical connection at the fuel pump on the outside.
Old Aug 15, 2009 | 01:31 AM
2006c6keller's Avatar
2006c6keller
Default Doesn't cost much if are worring about the price of water eliminator!
Also put some water eliminator in the gas tank won't hurt. Mine was stalling and the Corvette engineer at BG couldn't figure it out, BUT my pharmacist did, he said: "water in the gas" and he was right. Try it, it won't hurt. Talked to engineer at BG later and he said: "I didn't think of that". Now do it!
To 2005 stalling
