When putting in a route today I also put in a waypoint that I did not want. When the waypoint was removed from the route, I suddenly lost the street/turn directions in the HUD. Also, at the same time on the HUD, I lost the turn signal display as well, and no matter what I attempt I cannot get the turn signal indicators back in the HUD or the street/turn description back in the HUD as well. The owners manual on the NAV tells you that these displays will show on the HUD, but it does not seem to tell you what to do if/when they disappear, can anybody help?
Are you still in "Street Mode", perhaps you changed to "Track Mode" which doesn't show the directions, or turn signals on the HUD. That's the only thing I can think of why this might be happening.
I've used the "Track 2" mode since day one, and always had the directions and directionals. Why would it stop now?
Track 2 mode by design will not show the directions in the HUD, only street mode will. I'm not sure why your's did, it shouldn't. It simply isn't designed to project the turn by turn in anything other than street mode.
From the manual:
There are three HUD modes that you can choose to view
in the HUD display. By pressing the MODE button, you
can scroll through these modes in the following order:
Street Mode supports
audio and navigation
functions with your choice
of tachometer settings.
