Preparing for The Worst...
Old Aug 16, 2009 | 05:41 PM
Wilzer's Avatar
Wilzer
Default Preparing for The Worst...
So if I have a blowout or mechanical failure and have to call a AAA tow, insist on flatbed of course, where would the best place be to have the tow jockey attach the hooks to pull my vette on the the bed? Just want to be the **** sorta SOB I am and make sure I don't get added damage from the tow
Old Aug 16, 2009 | 06:01 PM
John Mclain's Avatar
John Mclain
Getting it up on the bed is probably easier then tying it down correctly and transporting.
We need to hope that the bed driver is watching the pot holes on the way to the garage.
My previous C-5 was tied down to the bed by the rims, I ended up with Two Warped Rims.
If I ever have to flat bed again I hope I have the opportunity to ride with the driver or the means to follow the rig.
Old Aug 16, 2009 | 06:02 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Some people suggest using the frame slots, where we put lift pucks.
Keep in mind that many tow truck drivers are Neanderthals. A good one will take care of your car without your help, a bad one will rush in there and trash things while ignoring your commands.
Old Aug 16, 2009 | 09:02 PM
REVAK's Avatar
REVAK
For transport :
Straps over the tires works well. Straps on the lower control arms near the cross member is also good. A general rule is most points that can take cornering and ,or, braking stresses or loads are safe.
For pulling :
Straps are preferable to chains. Do not pull from a single point.
A strap on each lower control arm near the cross member, tied to a single cable to split the load. <
Old Aug 16, 2009 | 09:04 PM
Bat Man's Avatar
Bat Man
, when I worked at ferrari we picked up and transported most of them by using cloth straps around the wheels. NEVER had a problem.
Old Aug 16, 2009 | 09:05 PM
Bat Man's Avatar
Bat Man
BTW: the truck driver should have some 2x10s at the very least to help get you up the ramp with out scraping.
Old Aug 16, 2009 | 09:09 PM
bob guzzy's Avatar
bob guzzy
If you just have a blow out the tire is cooked anyway, so have the guy drive the car up the ramp after putting a few 2x6's on the ground to clear the bottom flap,
Then attach the nets over the wheels to hold the car down, there is no need to drag the car up if it still runs.
Old Aug 17, 2009 | 01:50 PM
Wilzer's Avatar
Wilzer
Thanks, didn't think of that
To Preparing for The Worst...
