c6 angle eye head lights
Old Aug 18, 2009 | 03:46 AM
djwho's Avatar
djwho
Default c6 angle eye head lights
i wanted to install these c6 angle eye head lights anyone knw how to take the head lights apart???
http://i45.photobucket.com/albums/f9...g?t=1250581526
http://i45.photobucket.com/albums/f9...g?t=1250581592
Old Aug 18, 2009 | 04:07 AM
User 81424's Avatar
User 81424
Heat them up to what, 250 degrees or so, then separate the lens, then glue back together.
Old Aug 18, 2009 | 04:33 AM
djwho's Avatar
djwho
realli i had a extra head light layin around at my place ill see if i can find it and try testin it out do u know what kinda glue to use?
Old Aug 18, 2009 | 04:45 AM
User 81424's Avatar
User 81424
No and do a good search and a lot of reading before doing this!!!
Old Aug 18, 2009 | 04:59 AM
djwho's Avatar
djwho
yes im tryin to find info
Old Aug 18, 2009 | 08:49 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Keep us up to date, I like the look.
Old Aug 18, 2009 | 11:09 AM
RicK T's Avatar
RicK T
This is from one of Talon90's posts:
"The lenses are held on with a urethane bond which is very similar to the adhesive that is used for a windshield. It will not soften in the oven. These are not like some of the import cars that can be baked and removed. The best method for removing the lens is to use a dremel and cut around the seal. Once it is separated it is then possible to clean out the old adhesive and get some new urethane bond and re-glue it."
I remember reading here that it is "possible" to soften the sealant by baking it BUT...there is a fine line between heating the sealant enough to get the lens apart and actually melting the plastic and ruining it. So...just be careful if you choose to try the baking method.
Old Aug 18, 2009 | 11:33 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I can pretty much guarantee that if you haven't tried this before you'll either craze the lens or melt the housing. There's a very fine line between success and failure.
As for the Angle Eyes I talked with the company in California on a couple of occasions but never seemed to progress for some reason.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Aug 18, 2009 | 11:39 AM
Xedes's Avatar
Xedes
Do a search about those lights. There was a thread talking about them a couple of days ago. I believe the company that makes the halo had issues with them causing fires in Bimmers. I have a set that I never installed in my 330ci collecting dust because of those issues ( the worst $300 I ever spent).
Old Aug 18, 2009 | 11:43 AM
2006C6's Avatar
2006C6
I have a frient that tried this "baking" method with his import headlight, and ruined his headlight completely, im pretty sure he isint the only one. I would look at a different method.
Old Aug 18, 2009 | 11:45 AM
MNVette's Avatar
MNVette
Those bright angel eye lights have caused fires in BMW's because they draw far more power/generate much more heat than the stock angel eyes put out - the system wasn't meant for those lights.
As for installing them on a Vette - only someone who knows how to use a Dremel can get the light box apart - it won't come apart because you put it in the oven - you'll only melt it. Frankly, unless you're a professional body shop worker, this isn't a good idea - and the lights will probably cause damage to the structure when you install them due to the heat (assuming they don't catch fire).
Old Aug 18, 2009 | 11:47 AM
Xedes's Avatar
Xedes
They do look kind of cool. But they should be called "cat eyes".
Old Aug 18, 2009 | 12:13 PM
danl72's Avatar
danl72
I like it.
Old Aug 18, 2009 | 01:10 PM
texas_c6's Avatar
texas_c6
Great picture, I think BMW already calls their headlights "Cat Eyes" in advertisements.
Old Aug 18, 2009 | 01:18 PM
Drewstein's Avatar
Drewstein
If someone sold the lights already done on a core charge type deal I would be all over this. *hint* *hint* vendors.
Old Aug 18, 2009 | 01:51 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
They will come apart if your brave enough to try it. It's an expensive mistake if you Fail.
No dremel was used on these.
Old Aug 18, 2009 | 02:44 PM
djwho's Avatar
djwho
well i got an extra head light at home that was broken soo ill try to see if i can find it and take it apart see how it goes if its easy ill do it for sure thanks guyz
To c6 angle eye head lights
Old Aug 19, 2009 | 01:34 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Originally Posted by MAJ Z06
I really like the way it turned out!
I think I remember hearing/reading something about a person who took the Audi Angel Eye's projector lights and put them directly into the C6 (like a direct fit). I wish I could remember... it was like a year ago.
I would be interested to learn who did the one pictured and how it was done, or if there is a kit for purchase.
Old Aug 19, 2009 | 01:40 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
LightWurkz did the ones pictured. I talked with them several months ago. They cut the lens off and did the retro with the "eyes" then re-glued the lens.
We discussed doing a few sets with a more controlled method but the prices soon when through the roof.
Old Aug 19, 2009 | 01:45 PM
BAMF AE's Avatar
BAMF AE
now that it's several months later and the economy is worse, you should try again. I bet you the price came back down through the roof, and is probably on the floor
