lowering my c6
Old Aug 19, 2009 | 06:10 PM
hdman 49's Avatar
hdman 49
Default lowering my c6
Hello guys i bought a 2007 c6 stock height how much can i lower it on stock bolts you guys have any height recommendation? i dont want to slam it thanks greg
Old Aug 19, 2009 | 06:15 PM
timd38's Avatar
timd38
The front will go down more than the rear. I cut mine and installed these pads.
http://www.zip-corvette.com/Zip/prod...56F5F85E94165C
Mine is realllllllly low. 2" before the front air dam hits the ground.
Old Aug 19, 2009 | 06:43 PM
azc62006's Avatar
azc62006
Default lowering
i like to mod my car but i like to drive it also. when you lower your car more than it is for street driving you may not like it. there will be alot of places that you may not be able to go. resturants etc. where i live our entry points are high... i have to approach at an angle so as not to scrape... they look badass when they are lower it just isnt cost effective to replce parts when i break them because i wanted to lower my car.. just my thoughts on this
Old Aug 19, 2009 | 07:49 PM
timd38's Avatar
timd38
If mine was a daily driver, I would be in trouble.
One thing I learned a looooooooong time ago, you never mess with your daily driver.
Old Aug 19, 2009 | 08:24 PM
marc8090's Avatar
marc8090
Every car seems to be at a little different height from the factory but on average if you completely lower the front on stock bolts it should come down 1/2" - 3/4". The rear will come down less. If you want a more level look you'll have to either cut your rear bushings or use aftermarket lowering bolts.
Old Aug 19, 2009 | 08:31 PM
Boomer111's Avatar
Boomer111
Try and keep the 1 in. rake forward.
Old Aug 19, 2009 | 08:41 PM
superdutymike27's Avatar
superdutymike27
I got about 5/8" out of mine on the stock bolts with the bushings removed? But it looks nicer and drives about the same. Make a big difference in appearance though.
To lowering my c6
