Airbag light
Old Aug 21, 2009 | 10:10 AM
HyperX's Avatar
HyperX
Veteran: Marine Corps
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
Default Airbag light
So after 3.5 years of ownership, my C6 started to display the air bag light(first issue with the car). This is a 2006 C6, and I noticed that it started last week when it was close to 99 degrees outside. Is this usually a connection issue? or something more serious. I am already beyond my warranty period.
Old Aug 21, 2009 | 10:34 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
One common issue is that the wiring connector under a seat, usually the driver side, starts to come loose. That happened on our 2006 at about 40k miles. Of course there can be other causes, too.
Old Aug 21, 2009 | 10:35 AM
HyperX's Avatar
HyperX
Originally Posted by Gearhead Jim
One common issue is that the wiring connector under a seat, usually the driver side, starts to come loose. Of course there can be other causes, too.
Will check it out. Was there an official TSB on this?
Old Aug 21, 2009 | 10:39 AM
Gearhead Jim
St. Jude Donor '13
I don't know, but someonw who DOES know is bound to chime in.
Old Aug 21, 2009 | 12:02 PM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
Tell your SO to shut up and the light won't come on anymore.
Old Aug 21, 2009 | 12:22 PM
HyperX's Avatar
HyperX
I will try that and let you know!
Old Aug 21, 2009 | 12:47 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As noted, the most common cause that I have seen is with the connector / wire harness under the seat. The motion of the seat seems to chaff the wire. Worth noting however is that there are a lot of elements to the supplemental restraint system and it could be a number of causes. You might check out the connector under the seat but if you don't see anything real obvious you probably should have it checked by a dealer. If the light is on, your airbag isn't working properly and an accident is really the wrong time to find out it was something more serious. Just my .02. I am not aware of a TSB having been issued on the under seat connector but it would be part of any competent dealers diagnostic procedure.
Old Aug 21, 2009 | 10:10 PM
Sir James's Avatar
Sir James
Default airbag light on
I had a similar problem with my 05 and found a fix on corvette mechanic forum. Following what I found there I pulled the drivers seat out and found that the wire for my airbag was running under the power seat motor. Moved it to run above the motor and have not had the light problem since. Hope my problem and fix will help lead you to fix yours.
Old Aug 21, 2009 | 11:00 PM
danl72's Avatar
danl72
Yes, it is usually the wire connection with the drivers seat.
Old Aug 22, 2009 | 12:25 AM
mpuzach's Avatar
mpuzach
I've experienced exactly the same thing. In my case, the fix was the same as in yours.
To Airbag light
