Engine/Trans Authentication
As noted here often, Carfax may or may not tell you of prior significant damage to the car. It doesn't tell you anything about damage that was repaired without insurance being involved. Neither Carfax or the service history would tell you if someone had abused the car, blown up the engine, and replaced it themselves.
The vehicle identification number (VIN) plate is the legal identifier of the vehicle. The VIN plate is located on the upper LH corner of the instrument panel (I/P) and can be seen through the windshield from the outside of the vehicle.
The last five digits of the assembly plant sequential number are stamped onto the rear side of the front sill (tie bar). This number is the same as the last five digits on the VIN plate. The VIN plate also has bar code characteristics.
For the Engine:
The vehicle identification number (VIN) is located on the left side rear of the engine block (1) and is typically a nine digit number stamped or laser-etched onto the engine at the vehicle assembly plant.
The first digit identifies the division.
The second digit identifies the model year.
The third digit identifies the assembly plant.
The fourth through ninth digits are the last six digits of the VIN.
For the transmission, the serial number and ID are stamped on the bottom rear of the tranmission behind the pan. The translation is as follows:
(1) 5 = 2005
(2) Model
(3) Hydra-Matic 4L60-E
(4) Julian Date or Day of the Year
(5) Shift Built, A, B, J = First Shift; C, H, W = Second Shift
(6) Serial No.
(7) Transmission ID Location
