Active Handling System
Old Aug 26, 2009 | 09:34 AM
STEVE MC's Avatar
STEVE MC
Default Active Handling System
The warning light on the DIC for Active Handling has been coming on quite often latley so I decided to take her in for a diagnostic check.
I have a feeling the module may be faulty.
Anybody here have this problem with their C6?????????
Old Aug 26, 2009 | 09:40 AM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
Did you think to try the search function to find the dozens of threads that exist about it?
Just curious...
Old Aug 26, 2009 | 09:44 AM
STEVE MC's Avatar
STEVE MC
Just curious...
Thanks, I didn't think of it since I have never seen a thread on this subject. I'll check it out.
Old Aug 26, 2009 | 01:09 PM
shopdog's Avatar
shopdog
It is very unlikely that you have a module fault. If you did, I'd expect you to be seeing ABS error messages too. The most common cause of AH messages is a loose connection to the yaw sensor in the steering column due to tension on the wires when the telescoping column moves in and out. This is a 5 minute fix, just push the connectors back together and add a tie wrap to make sure they don't work loose again.
Old Aug 26, 2009 | 01:21 PM
cclive's Avatar
cclive
Even more likely if you use the telescoping feature alot, like getting in and out of the car....
Old Aug 26, 2009 | 02:13 PM
STEVE MC's Avatar
STEVE MC
Thanks Shopdog, I did find a thread refering to this problem. It was from 2007. Apparently it was coming on during an autocross event. Makes sense now
Yes, I have a 3LT so every time I press the memory button it moves forward then back when I get out.
Old Aug 26, 2009 | 02:15 PM
lander's Avatar
lander
There's a clip you can buy from GM for like $10 that you insert into the wiring harness under the dash that will take care of this issue. Search on "SAHS", you'll find a thread I started with the full explanation, part numbers, etc. I did it a month or so ago and the problem went away.
Old Aug 26, 2009 | 02:20 PM
STEVE MC's Avatar
STEVE MC
Thanks, but shouldn't the dealer install the clip under warranty?
Old Aug 26, 2009 | 02:31 PM
lander's Avatar
lander
Yes, there is a new TSB on it, just point them in that direction to ensure they put the clip in and not the wiretie/electrical tape fix which is the old TSB.
Mine had the wiretie/tape which I had to remove in order to install the clip. Takes all of ten minutes.
Old Aug 26, 2009 | 04:06 PM
inthehunt2's Avatar
inthehunt2
Steve - Here's a more recent thread from May 2009. It's long, and it's scary. Take a read. Nothing to screw with. Nothing like having your Vette make a right hand turn on it's own at the top of the Tallahasee (sp?) bridge... Please see this link...
http://forums.corvetteforum.com/c6-t...er-action.html
Old Aug 26, 2009 | 10:56 PM
STEVE MC's Avatar
STEVE MC
Thanks for the link.
Mine says Traction Control Off on the DIC when it happens. Then when I press the button it turns back on but I cannot access the Comp Mode. The warning light stays on until I turn off the car.
Old Aug 28, 2009 | 11:39 AM
STEVE MC's Avatar
STEVE MC
Took the Vette in to the dealership today.
The service invoice read as follows;
Caused by poor terminal contact at SWPS per TSB document 2032653.
Cycle SWPS connector and install TPA clip on connector C202 and return vehicle to owner for evaluation.
It was a quick fix as some have already mentioned and was covered under warranty.
I will keep forum members posted if the SAH light should come on again in the future.
Old Aug 28, 2009 | 11:45 AM
lander's Avatar
lander
You should be good to go! The clip fixed mine...but I did it myself since my car wasn't under warranty.
To Active Handling System
