Can anyone shed any light on this for drag racing. What mode if any do you use? I heard performance mode will work fine however are you losing anytime with this mode if rolling out and hitting the gears???
I'm sure there are better suggestions out there as I can barely get just below 13 et but here is what I found:
WITH TC, it almost has no difference what rpm you preload and dump the clutch at and you will still get around the same time.
With TC off, I've tried (many times each) from idle to 5000, every 1000 or so, and the best I found is around 2-3000 but be sure to feather a little, else the tires never get traction.....fun yes.....quick, no.
My best time is with TC off but I have more bad times with it off also than with it on.
