Lowering Consequences...
Old Sep 3, 2009 | 03:00 PM
jpuli28's Avatar
jpuli28
Default Lowering Consequences...
Since lowering I have YET to gauge where the front bumper is If I put a spoiler on or change out to Sic's Z06 front end Im gonna cry
As well, I back in "most" of the time but then I occasionally hit the rear sway bar on the parking stop! Has anyone had to replace the rear swaybar because of this?
Old Sep 3, 2009 | 04:18 PM
Justasheet's Avatar
Justasheet
How low did you go? I listened to everyone and cut my stock bolt bushings to the "Top bun" of the hamburger in the back and uncut in the front. I actually had to raise the rear a little after cutting them to maintain the same tire/fender gap as in the front.
I scrape the front air damn and slightly rub the front "Skid plates?" on my driveway but that is it. In the back, I'm fine and can back up my Rhino ramps without my 2x10 ramp lift.
As far as the front goes, I only bumped the nose once and I learned my lesson.
You may have lowered much more than me. Maybe too much??? Good luck.
Jeff
Old Sep 3, 2009 | 05:33 PM
gatti-man's Avatar
gatti-man
My c6 never rubs. Just don't slam it and if you have raise it back up a bit.
Old Sep 3, 2009 | 06:03 PM
One Bad Vette's Avatar
One Bad Vette
There are no consequences other than looking great. Mines slammed and I havent hit anything yet. Just dont try and pull all the way in and your good. I do scrape my plastic air dam leaving my driveway, but nothing painted.
Old Sep 3, 2009 | 06:07 PM
America'sSportsCar's Avatar
America'sSportsCar
After lowering, many recommend getting an alignment job so your tires will wear properly.
Old Sep 3, 2009 | 07:43 PM
jpuli28's Avatar
jpuli28
Never said anything about rubbing, Im a good 1,1/4" off the wheels.
Airdam Im not worried about. Its a bittersweet tradeoff.
Alignment was done, Im curious about rear swaybar replacement...
Old Sep 3, 2009 | 08:04 PM
BuBbABFP's Avatar
BuBbABFP
I lowered mine all the way down on aftermarket bolts and my sway bar never hit..front air damn will rub in my driveway but can be avoided if I come to it at an angle.
Old Sep 3, 2009 | 08:15 PM
OneBadZ06's Avatar
OneBadZ06
St. Jude Donor '08-'10
In the worst case scenerio, if you do need to replace the oem rear sway, they are fairly common take-off parts (the oems are pretty thin compared to all aftermarkets versions), so you can find them in the C6 parts section here often for around $100.
Old Sep 3, 2009 | 09:16 PM
gatti-man's Avatar
gatti-man
By rubbing I meant my car hitting the ground or obstacle.
Old Sep 3, 2009 | 09:26 PM
RogerC6's Avatar
RogerC6
From: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
I always back in to park, even before lowering........man it sure looks great low...
To Lowering Consequences...
