I have an '07 A6 with about 26,000 miles and has had a lot of stop-and-go city driving.
Sometimes while waiting at the light (in gear), especially with the air-conditioning on, the RPMs will drop momentarily, almost to the point where it feels like the car might stall. Normally my car idles at 550 in gear.
I was wondering if I might have carbon in the throttle body and should I get this cleaned (or can I do myself)?
Any thoughts will be helpful.
That thing should be under warranty (36k/36mo), take it to the dealer and let them solve the problem! GO!
It is under warranty but my experience with dealers is that they will not entertain any such problems. If indeed it does need the throttle body cleaned they will charge an arm-and-a-leg for it calling it routine maintenance.
Get a can of throttle-body cleaner at your local auto parts store and see if it helps. If not, take it in.
Could perhaps be a dirty MAF too..........
Service manager here stated that the MAF did not usually need cleaning. He said some individuals spray too much oil on filter and mess it up. He mentioned that when you turn off the car that wire heats up and burns debri etc. off the MAF wire; therefore, doesn't need cleaning. He did mention to be careful with the wire if you clean which is very small and CAN BE BROKEN EASILY. Anyone else have experience, please chime in. I do not plan to clean mine anytime.
The Air Flow Sensor or Mass Airflow Sensor (MAF) is one of the components of an electronic fuel injection system and is found in many of modern vehicles. The Mass Air Flow sensor is usually installed inside the intake air duct between the air filter and the engine. The Mass Air Flow sensor is used to measure the amount of air entering the engine. This measurement is used by the engine computer or ECM to calculate proper amount of fuel injected into the cylinders in order to provide optimum combustion and low emissions.
Over oiled air filters can foul the MAF sensor. Use electronic circuit board spray cleaner, this will clean and dry leaving no residue.
Thanks for the refresh, that what I was looking for again, you nailed it. It was about 3 years ago that I had a conversation with the service manager on MAF about too much oil on air filter and it affecting the MAF.
