non runflats
AAA, it takes for them some times over 2 hours to get to you.
how do you fix that problem?
is it worth it to switch from runflat, is it that big of a differents?
However, some folks like to track their car or only drive on the weekend during the day, in that case it would be much less risky.
In 43 years of driving (since I was 16) I've had exactly 2 flats, and both were slow leaks. Once I got rid of those awful runflats, the Corvette was a different car. I actually saw what the potential of this awesome car could actually be.
The downside is, I then spent upwards of $30k in mods
But the Fix A Flat is very unfriendly to your TPMS
ps: just got home from our 6,243 mile trip to BG and not a single tire problem
Would never have rf's on my vette. Stiff suspension + rock hard tires = uncomfortable ride + compromised handling IMO.
if you go for the plug and compressor... keep in mind, get the tire repaired properly asap when you can, dont rely on the plug repair being the final fix. The one problem with it over a run flat is, what if the injury is too large for a plug..?...
again, tough decision. personally, i plan on ditching my run flats to get the better handling and ride from a more suitable tire for this car.
( when the time comes...going w/ the Michelins )
I just like the security of the rf's
- what are you looking for in a tire (cost, performance, ride)
- how do you drive
- where do you drive
Yeah the old question about, "What if I get a flat"...I have roadside assistance and if I had to replace one of these tires it wouldnt break the bank either. There are several guys in our club that have non RFs on their Vettes and no one has had any issues (one is a Z06).
what is a popular replacement brand that people use?
The repair kit did not supply anything but the plugs and tools to get the plug in. Fortunately it was at the the house. I needed needle nose pliers and a flat head screwdriver to get the thing out. I had to jam the screwdriver into the tire in order to get any grip on it for the needle nose. That thing was really in there. That taught me a lesson.I got to thinking about it, and decided to prepare myself for the worst conditions possible - Raining at night with a screw in a rear tire on the INSIDE(How are you gong to get that fixed without crawling under the car?) and the tire won't hold air, in a place that did not have cell phone coverage.
My kit now contains a small compressor with a light, needle nose, round nose pliers. flat head screwdriver, a headlamp, rubber gloves(it is a filthy job), a small bottle of soapy water, a tire repair kit(get a good one, not a cheap Kragen's deal) My first kit was a cheap one and the shaft went through the handle the first time I tried to push in a plug. I also carry a 1/2 breaker bar, lug nut socket, and a small jack from a Taurus($8 bux at the local junkyard). A blanket and a cheap $3 poncho I can pull the tire, get the screw out, plug it and be back on the road before Triple AAA shows up with a flatbed, Yes a flatbed, AAA will not fix a flat, they will come out and put on a spare(Check your roadside service policy, mine clearly states what they will do). When I got my second flat at work, I was third in line for next available flatbed, 2+ hours to wait.
Sounds like a lot of stuff, but it all fits in the back cubby in a stuff sack and the jack is in the center cubby(C5).
I put Michelin Sport Pilot II RF's on the C6 and am very happy with them. When the Nitto's need to be replaced I am going with the Pilot RF's.
The plug kit and compressor are OK but If you get a flat you still have to stop, find whatever is in the tire, and plug it. Not fun If it is raining, or your dressed or not in a nice area. place.
