dash lights dimmer ?
Old Sep 23, 2009 | 01:09 PM
white top's Avatar
white top
Default dash lights dimmer ?
I am new ownerof 09 coupe and the dimmer control seems to have little/marginal range from low to high on the dash lights. Yes Ihold the switch as stated in the owners manual.Anyone else expierence this?
TIA Jerry
Old Sep 23, 2009 | 01:33 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Daylight or dark? Can't really see what you're doing unless you are in the dark and have the lights on.
Elmer
Old Sep 23, 2009 | 01:47 PM
StanNH's Avatar
StanNH
The switch is about the same quality as the ashtray cover. It has a limited range of adjustment, even if held. It's also the on/off switch for the interior lights on the mirror, so be careful you don't accidentally push it in. There is no indication that it is in the on or off position....brilliant engineering.
Old Sep 23, 2009 | 01:49 PM
tls630's Avatar
tls630
I don't know how it is supposed to work mine is broken...It is a very cheap switch..
To dash lights dimmer ?
