Clutch/Tranny problems
Old Sep 25, 2009 | 10:36 AM
brian18330's Avatar
brian18330
Default Clutch/Tranny problems
I have an 06' 6 speed and its hard getting into gear on down shifts, and the clutch lets out real high. 37,000 miles....maybe needs a new clutch? Also there is alot of clunking noises coming from the rear when in reverse or first gear starting off. Thanks
Old Sep 25, 2009 | 12:54 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
yes, I'd say something's up with the clutch. Lotta things could be happening with the rear clunk in reverse tho incl. axle nuts, fluid change, clutchpacks, shafts, bearings, etc.
btw, don't keep forcing the downshifts 'cause eventually you'll wear out the synchros. that'll be even more costly.
