Front end damage?
Old Sep 28, 2009 | 11:31 AM
pmuney's Avatar
pmuney
Default Front end damage?
I noticed the other day that there seems to be a broken snap, or bracket or something near the hood of the car. I put the picture as my profile picture. What can I do to fix this? It seems like a snap just broke.
Old Sep 28, 2009 | 11:43 AM
mupepe's Avatar
mupepe
Mine does that too. Just push it back in. Mine pops up every few weeks. I just snap it back in.
Old Sep 28, 2009 | 12:03 PM
corvettenvy's Avatar
corvettenvy
I have 2005 coupe I purchased one month ago and it has the same problem. When I push it back down, it does not last weeks but only until I drive it again. Hopefully we can get some suggestions from owners who have dealt with this in the past!
Old Sep 28, 2009 | 12:51 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I'm your man.
Last year my 2006 got hit in the front, all the plastic forward of the doors was replaced. When finished, it had the same "flip up" in one corner that you have.
There are two different clips on each side, the body shop said they did not fit very well on the GM replacement bumper/fenders. They finally went in and redid it right but I'm not sure exactly how. After a recent conversation, I suspect they removed the fender liner and added an additional non-standard fastener on each side, that's just a guess.
Many of the current cars (including my 2009) come out with some "flip", but not nearly as much as yours. If they remove the front bumper to reinstall or somehow tighten the clips, be aware that most shops have a difficult time getting the bumper back against the fenders as tightly as before.
There are several threads about this from around March-May of this year, you might try a search under my name.
Good luck!
Old Sep 28, 2009 | 02:16 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
thats the easiest clip to break on the front end, you can get new ones for around $7 from the dealer. You'll need to firmly press the bumper corner down to make it stay.
Old Sep 28, 2009 | 02:21 PM
Nuclear28's Avatar
Nuclear28
I can't find the picture of what he is talking about
Can someone help me out?
Old Sep 28, 2009 | 02:53 PM
Gearhead Jim
St. Jude Donor '13
Click on his user name, then click on his profile. The picture is there, a little small but usable. The headlight is on the right, hood is on the left.
Old Sep 28, 2009 | 06:06 PM
Nuclear28's Avatar
Nuclear28
Thanks! I have the same issue! Both flaps have poppped up. I cannot push the bumper closer to close the gap, it always goes back to the raised position. I'm also interested in these clips and how to replace them!
Old Sep 28, 2009 | 08:52 PM
Gearhead Jim
St. Jude Donor '13
I should add that the plastic body panels move around a bit depending on temperature. When I bought my 2009 in June, the dealer had two absolutely identical cars in stock, I got to pick which one I wanted. So I spent a couple of hours looking them over, in the shade and in the sun, and noticed the "flip" would vary depending on how warm the car is.
The one I bought is sitting in our garage right now on a cool night, about 55 degrees. Flip is virtually gone. Park it in the sun on a hot day and it becomes more noticable.
Old Sep 28, 2009 | 10:25 PM
St.Char's Avatar
St.Char
Lift the hood and try to push it back in the clip. While you have the hood open, you can see the clip where the bumper clips on to the fender. You may need a new clip, however, it will require some dis-assembly of the bumper.
I've had my bumper off around 3-4 times this summer and still on the same clips without issue. Good luck!
To Front end damage?
