It apprears I have a Garage Door that uses a Rolling Code and an outside subdivision security gate that uses a fixed code. Can I program my Vette Universal Home Remote using a rolling code for one button and then a fixed code program for another button for the Universal Home Remote on the Vette's Visor?
The three buttons are completely independent, just as if you had three separate remotes. And if you can't get it done, call the 800 number, they are very helpful...
It took only a few minutes to get mine working, and I have exactly the same situation you do. You will need to open the gate transmitter to write down the switch settings, but the manual is clear. Also, I did the gate programming early on a Sunday morning, because you don't want anyone else using the gate while it's being done.
