need some body help
Old Oct 1, 2009 | 01:41 AM
hymnatr's Avatar
hymnatr
Default need some body help
The front bumper is lifting at the corners where it meets the lights. Does anyone know what is causing this, has it happened to anyone else, and most importantly how do I fix it???
Old Oct 1, 2009 | 02:18 AM
Salt's Avatar
Salt
Others have reported similar problem, not sure what the solution was, if your car is still under warrenty check with your dealer, if not than you'll probably end up at a body shop, I'm guessing but I think it was caused by a faulty body clip? Good luck in your search, maybe someone who had the same thing will respond soon,
Old Oct 1, 2009 | 03:52 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Mine just started doing it too. It is the clip not staying in.
David
Old Oct 1, 2009 | 11:33 AM
Dans C6's Avatar
Dans C6
I noticed that my passenger side headlight has more of a gap with the gasket compared to the driver side.
Old Oct 1, 2009 | 02:20 PM
hymnatr's Avatar
hymnatr
this should be covered under warrenty then
To need some body help
