thermostat help
Old Oct 2, 2009 | 12:21 PM
tr79849's Avatar
tr79849
Default thermostat help
I just installed a 160 degree hypertech thermostat. i keep the dash on coolant tempature and was wondering if it suppost to read 160? because mine keeps going up and down. The highest it's gone was 211 when idoling and 185 when driving....Well thanks for reading.
Old Oct 2, 2009 | 12:48 PM
ydeer's Avatar
ydeer
i have a 160 and my range is 174 to 205. i have a couple of mods. car was tuned at rev/extreme on a dyno. car shouldn't get down to 160. hope this helps. it seems that you are running ok at those temps
Old Oct 2, 2009 | 12:53 PM
ROBERT ALFORD's Avatar
ROBERT ALFORD
Default Thermostat
At idle it will be hotter because water pump is not turning very fast.
Also did you bleed air out of system after installing thermostat as that
will cause temp to go up and down.
Old Oct 2, 2009 | 02:28 PM
tr79849's Avatar
tr79849
hey thanks guys...yeah i had it installed at a dealership.
Old Oct 2, 2009 | 02:37 PM
cranky's Avatar
cranky
you need to have the fans turned on sooner. this is done by a tuner. if not, the temp will rise up until the fans come on when operating low speed.
Old Oct 2, 2009 | 03:25 PM
iridelow's Avatar
iridelow
it's not a good idea to change your temps unless you have your car tuned. The car is tuned from the factory to run at a factory temp!
Old Oct 2, 2009 | 04:39 PM
KB9GKC's Avatar
KB9GKC
Douglas in Green Bay
Old Oct 2, 2009 | 06:43 PM
mforman42's Avatar
mforman42
Yeah. A 160 thermostat does not mean the car will run at 160. It just means the thermostat opens at 160.
To thermostat help
