Replacing an ECM
Old Oct 5, 2009 | 03:51 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Default Replacing an ECM
What's involved with replacing the ECM on a 09? I removed the panel in the fender well and it looks awful tight up there! Does the fender need to come off?
Old Oct 5, 2009 | 04:09 PM
cranky's Avatar
cranky
nope, but hope you know what you are doing. these units are not plug and play. will have to be flashed by the dealer to make operative. good luck
Old Oct 5, 2009 | 04:59 PM
08vycpe's Avatar
08vycpe
Cranky is right. The only way to replace an ECM is to have the dealer program it to your exact VIN using a Tech II.
Unless you have a friend with a Tech II and the latest software that includes your VIN you are out of luck.
Old Oct 5, 2009 | 05:23 PM
rebel7777's Avatar
rebel7777
Wouldn't EFILive work in this application for a new or used ECM installed in your new corvette. I checked their website and they support 06-09 vetts. We do ECM swaps on our diesel trucks all the time for warranty issues.
Old Oct 5, 2009 | 07:30 PM
budmont's Avatar
budmont
I have a spare ECM that’s been programmed, VIN matched. I’m looking for info on getting it out.
Old Oct 5, 2009 | 09:47 PM
cranky's Avatar
cranky
Comes right out the bottom. You have to unlock the connectors. They have small plastic keys. Once the connectors are unlocked, the plugs unplug and you remove the screws to get the pcm out.
Old Oct 6, 2009 | 02:05 PM
budmont's Avatar
budmont
So your saying that you've done one?
Old Oct 6, 2009 | 02:34 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default OR, you could send it to Chuck CoW....
On 09' models it's up there much higher than it was in earlier models.
If the car is a ZO6, be careful...The fender is practically an egg shell and if you fight with it, you could damage the fender.
As I recall, the easiest way is to remove one of the 10mm headed bolts that holds the ecm to the bracket or something like that.
Removing it allows the pcm (with plate it sits on) to be lowered making it easier to remove and re-install.
It's not that hard as long as you have loooong arms.
Chuck CoW
Old Oct 6, 2009 | 04:26 PM
BEZ06's Avatar
BEZ06
I replaced one on my 2005 and it was very easy.
I dropped shipped a new PCM to my tuner and he loaded a tune into it and also loaded my VIN so it would match and I could start the car.
If you're putting a brand new PCM into your car that has been VIN matched as mine was, you should be able to drive the car but you'll throw a code until you get a "crank variation relearn" procedure done (at least that's what I think was required).
Chuck CoW can you confirm that I've got the correct terminlogy?
Bob
Old Oct 6, 2009 | 04:29 PM
Robls6's Avatar
Robls6
Is there something wrong with it?
Old Oct 6, 2009 | 08:04 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default It's a bit more than that....
Bob
A new, un-used pcm (one that has never fired an engine before) will automatically learn the security key from the BCM the very first time and engine is started with it. (this is what happens on the assembly line at the GM plant) It's not a matter of putting the vin# in it, but either modifying the VATS procedure or just purchasing a new unit.
You can either turn off the "crank variation learn not performed" code or find someone with a TECH II and a CANDi Module to perform the Crank Learn Procedure.
It's pretty easy and my customers do it all the time.
If you're not in an area where you can get my tune in person, all you have to do is remove the PCM and send it to me.
Stay TUNED!
Chuck CoW
Old Jul 21, 2019 | 02:53 PM
Marcelino Martinez's Avatar
Marcelino Martinez
2nd Gear
Default 2008 z06
Stay TUNED!
Chuck CoW
I have recently purchased a PCM from a company who programmed it to my Vin number . But after installing it in the car still will not crank. I’ve read that is not a plug and play but it will still not turn over so I could get it to a dealer or somebody with a tuner or tech 2 . Did I receive a bad PCM if so I would like to send it back and get one from Chuck Co does anybody have their information address phone number anything would help to get a hold of them
To Replacing an ECM
