Rear Disk Breaks
I'm not an expert either. Far from it.
But, I can say the same that other(s) have said... don't mess with the brakes' front/rear ratios, etc. Chevy engineers have their jobs for a reason, and you don't want to mess with stuff without knowing what you're doing. Yeah, fine, this forum is nice. And, there's a lot of good information that can come out of it. But, there's a lot of BS too. My 2-cents says: are you really going to put your LIFE in the hands of some forum member that says "go with this braking solution"?? I know you said money is an issue. But, unless you're talking about going to a TRUE expert that has a track record and can guarantee braking performance, I'd say not to mess with what the Chevy engineers have already put together for you.
The idea: "I want to modify my brakes, but I don't want to spend a lot of money doing it"... just rubs me the wrong way in all kinds of angles. "You get what you pay for" is my first reaction, and I have several other reactions right behind that one.
"please don't take this as confrontational as it may sound, but, given the fact that you cannot even SPELL "brakes" (you spelled it as "breaks") I must assume that you're not an expert on them.
Give me a break
It is best to just leave the Corvette factory stock the way it came form factory as that was meant be a reliable performance sports car. Mess with it and you will have all kinds of problems with the electronics, sensors and computers.
If you want better stopping power you will need to change your calipers as well as rotors and this will end up causing you to get different wheels with a different offset.
On the 2005 to 2008 C6, all models used the same EBCM made by Delphi - whether there are different ABS algorithms for the base C6 and Z06 nobody is sure, but I think it's the same part# for all the C6 models.
With the 2009 model year and the intro of the ZR1, GM changed the supplier to Bosch, and no one is sure if the ABS would work properly if you put the carbon-ceramic ZR1 brakes on an earlier Z06. IMHO, there wouldn't be any problem at all - the ABS sensors just simply send wheel rotation speed to the EBCM and the software (whether is Delphi or Bosch) will reduce pressure to a brake when the wheel slows too much indicating an impending skid. However, there may be more or less pressure reduction required with the different brake materials.
Even on the Z06, if you wanted to put on the ZR1 brakes, I think you'd need larger wheels to fit over them.
Forum vendor Gene Culley says he can provide a set of ZR1 brakes for $8,000 but so far no one has wanted to try it.
Callaway has an option on one of their Vette upgrades for carbon-ceramic brakes. It's a $15,600 option!!!!
So.....to put the ZR1 brakes on a C6 Z06 I think you'd need the ZR1 19"/20" wheels, and for a regular C6 you'd need a wide-body kit and the larger wheels.
On Porsches you can get carbon-ceramics as an option for something like an additional $12,000. I've followed GT2 and GT3 Porsches into corners, and you can tell the ones that have carbon-ceramic brakes because they can go a lot deeper into a brake zone before you see their brake lights come on.
If you're racing and your class rules allow them, then they would definitely be the brakes to have.
For my street car that I only take to the track 6 or so weekends a year for fun driving on the track, I don't feel the need to spend that kind of money.
Bob
However, the Baer 2 piece rotors reduce weight from the OEM rotors, my tires reduce weight from the OEM runflats and my wheels themselves are much lighter than the OEM wheels, so I would say overall I do get better stopping performance all things considered
Bob
$8,000!
My brakes are just fine the way they are to suit my driving sytle. At that price you better not have to worry about brake dust. or do any cleaning for brake dust.
I agree with your comment that the OP was talking about looks - I just wanted to point out that the braking may not be changed. I also agree that the weight savings of the two piece rotors is a plus and may end up braking better due to the overall design of the rotor.
