LS3, LS7 High Flow (Washable) Replacement Filter GP!!
Old Oct 9, 2009 | 12:48 AM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Default LS3, LS7 High Flow (Washable) Replacement Filter GP!!
To launch our LS3, LS7 High Flow Washable Replacement Filter we thought we would start with Group purchase!
$104.99 ship to your door! (lower 48 states) Need 25 orders to meet the gp
Finally, a high flow LS3 & LS7 Replacement filter that is washable / reusable!
Perfect for those who don't want to change their stock intake system but want a washable filter and much more air!
*Fits perfect in your stock GM intake. Use your original filter retainer when installing!
*Stock filters clog up which results is loss of power.
* No more throwing out clogged filters. This filter is washable / reusable for reliable service!
*Its Patent Pending low restrictive "open" design allows a much greater volume of air to flow through your intake! Flows a whopping 45% more air then Stock!
*The filter material almost meets/touches in the back (inside the filter), no "wall" for the air to smack into and cause turbulence. Practically no restriction.
*The filter is washable and reusable for extended, reliable service!
Reinforced base to guarantee NO warping. No leaks! Reinforced Wire support to handle high CFM.
*Whats important is it meets & exceeds all of the new, stringent filtration ISO 5011 SAE testing!
To order please call in 516 593 9093 10am-5pm Monday- Fri Sat 10-2pm
Use Cleaning kit 1001-82T
__________________
Serving The Corvette Forum For 25 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
God Bless America!
Old Oct 9, 2009 | 09:22 AM
mirage2991's Avatar
mirage2991
I'm in! I'll try to call today...anyway we can order it via your website?
Old Oct 9, 2009 | 10:00 AM
dwiemers's Avatar
dwiemers
This looks like a decent deal, instead of buying a replacement GM one, then I would want to buy this! Would it set off any CEL's? What if it does?
Old Oct 9, 2009 | 11:05 AM
Xwet's Avatar
Xwet
I got mine.
Old Oct 9, 2009 | 11:32 AM
Jethro66's Avatar
Jethro66
6th Gear
I'm in.
Old Oct 9, 2009 | 11:39 AM
speedraider's Avatar
speedraider
any surging problems or throwing codes, I know the ls3 is sensitive
Old Oct 9, 2009 | 11:51 AM
JoesC5's Avatar
JoesC5
Am I correct in assuming this filter has to be oiled after washing?
Old Oct 9, 2009 | 01:26 PM
TKO Performance
Thanks guys for the orders, I'm also calling others as fast as I can.
Its a real quality piece. Feels even good in your hand.
Should NOT set off any cel's.
Yes. We have a cleaning kit specifically for this filter. (Based off our MAMABA air intake)
Item# 1001-82T
Old Oct 9, 2009 | 02:34 PM
mirage2991's Avatar
mirage2991
is the K&N cleaner kit compatible ?
Old Oct 9, 2009 | 02:47 PM
bass mechanic's Avatar
bass mechanic
i would be interested
Old Oct 9, 2009 | 03:54 PM
TKO Performance
I'm not sure. I'll have to find out.
However it does come pre oiled. The kit listed above is desgined for our media and system
Old Oct 9, 2009 | 04:25 PM
haljensen's Avatar
haljensen
Wow! You beat K&N to the market, they still don't offer a replacement filter.
Old Oct 9, 2009 | 04:51 PM
TKO Performance
Used the same design/ philosophy from our MAMBA air intake system.
Old Oct 9, 2009 | 05:30 PM
WhItEKnIgHt23's Avatar
WhItEKnIgHt23
Any hp/et numbers? How's fitment? Any cheaper for local pick up? Also curious how it would be with the "sensitive" ls3...
Old Oct 9, 2009 | 06:46 PM
ATC399's Avatar
ATC399
any pics showing the back side of this filter?
Old Oct 9, 2009 | 06:53 PM
Silver05GTO's Avatar
Silver05GTO
Any hp increase would be a BONUS. This filter is a great alternative compared to buying a stock filter for nearly the same price that must be thrown out after 40-50K miles. Probably be the last air filter your car would ever need
I'd bet the Vette-Air scoop and this filter would make for a great combo for those ok with shroud cutting.
Old Oct 10, 2009 | 12:43 AM
TKO Performance
Its a group purchase. We hit 25 orders, shipping is free!
Works fine with your LS3
Exactly. It was our intent to create a quality filter that was washable & reusable.
Stock paper filters clog which results in a loss of power, and then get tossed (along with your money). Our cotton media helps keep your filter breathing deep longer. And of course its washable/ reusable for long lasting reliable service!
Typically to really see big gains or take advantage of any aftermarket intake, you would have to tune/ trim settings. With our unique design, that option is here with our filter too (without the cost of the intake).
Although more air should antiquate to some more power (especially at the super flow rate this puppy has over stock) just by dropping it in.
CHECK OUT THE COMPARIASON TEST VID http://www.youtube.com/watch?v=Q5DDR...r_profilepage#
To LS3, LS7 High Flow (Washable) Replacement Filter GP!!
Old Oct 10, 2009 | 10:42 AM
bass mechanic
come on now, thats not a fair comparason in the video! if you want to earn the trust of a bunch of new prospective buyers dont send us a video which is obviously inaccurate!
your filter doesnt even seal on that tester. all the air is running under the sides, across the front of the box and into the hole without passing through the filter at all!
FAKE!
you need to build somthing to show the air actually passes through the filter media
take a vette air intake with the filter installed and make an adapter to fit the round end of the intake so it will seal up against the test box.
just cut a peice of cardboard that fits over the box and a hole that fits over the stock vette filter housing.
run the test with no filter as a baseline, then with yours and then with a stock filter
and if the results show better airflow then you have my vote and my order.
but to post a video like that makes me think your hiding somthing!
Old Oct 10, 2009 | 10:56 AM
TKO Performance
FAKE!
There is a templete of 2 "half moon" like cut outs on each end on the bottom of our filter which creates a square and seals to the box's square hole. So the results are in fact true/correct.
We explained we did this in another thread, forgot to list it here.
We also explained that we will probably be doing another vid, showing the bottom of our filter right before placing it on the box, for that reason.
Old Oct 10, 2009 | 12:33 PM
bass mechanic
its still not a fair comparason because the stock filter media has a design that only allows the air to flow through the section area of the opening on your test machine. your comparing only about 25% of the total surface area of the stock filter to the entire area of your filter.
you need to make a test as i described, take a stock air intake from a vette and make a simple cardboard template. hold the template over the hole on the tester so that the air going through the test unit is exactly the same going through the entire filter and stock airbox.
this would prove without question which filter works best and with the stock air intake. this way the ENTIRE OE filter gets used and is compared with your filter.
i am sure someone would be happy to let you borrow their airbox for the test. i would be curious to see if the stock airbox has any notable restriction without a filter as a baseline on that tester.
that tester is designed to take a filter that fits the area of that hole. the stock airbox opening that attaches to the throttle body is significantly less area and i would be suprised if it didnt show some restriction just based on that fact alone.
