Flash 2 Pass
Old Oct 10, 2009 | 01:17 AM
ER Doc's Avatar
ER Doc
Default Flash 2 Pass
Does anyone here have any experience using this system with the C6? It looks promising. Also, does it have to be connected to the high-beams, or will any switched 12-volt source work?
Old Oct 10, 2009 | 01:32 AM
LS WON's Avatar
LS WON
Old Oct 10, 2009 | 01:46 AM
gogetum's Avatar
gogetum
The Yankees are up 2-0
Old Oct 10, 2009 | 02:03 AM
CO Lightfoot's Avatar
CO Lightfoot
At first I thought you were asking about the "Flash-to-Pass" feature on the C6 high beams. This causes the high beams to flash several times when you pull the turn signal level toward you.
But I think you're asking about a garage-door opener that operates using the high-beam switch: http://www.f2ptechnologies.com/
I'd worry that the "Flash-to-Pass" feature would cause the "Flash2Pass" system to send multiple signals to the garage-door opener (one signal for each high-beam flash).
If so, then the garage door might start to open, then stop, then start, then stop... it might never open!
Alternately, it seems like any 12-volt source will do the job. Maybe someone with experience will chime in. (Or you could just ask the manufacturer. )
Old Oct 10, 2009 | 02:07 AM
beachfrontvette's Avatar
beachfrontvette
Originally Posted by LS WON
I always thought "flash to pass" was about pullin up the old tshirt
Old Oct 10, 2009 | 03:12 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Me Too
Old Oct 10, 2009 | 06:14 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
It appears it would work from any switched 12 volt supply. The transmitter only has 2 wires so it is simply looking for 12VDC on those wires to send the radio signal. How that 12v gets there is irrelevant.
Old Oct 10, 2009 | 09:48 AM
dvilin's Avatar
dvilin
To Flash 2 Pass
