Need help, won't start
Old Oct 10, 2009 | 01:46 PM
phoenix's Avatar
phoenix
Default Need help, won't start
I'm pissed. The car was fine yesterday morning. I parked in the garage and took my truck to work.
We are having construction done in the basement and it was raining so the builders decided to do their sawing in the garage. The car is covered in MDF dust.
I planned to clean it before I head out this morning and it won't start. I tried charging the battery, it will click but the engine light comes on.
I can't imagine that this is coincidence. It has to be due to the dust in or on a sensor.
Any ideas? The Chevy service dealer is not open today here.
Thanks,
Old Oct 10, 2009 | 02:37 PM
LMB-C6's Avatar
LMB-C6
I would doubt it's the dust. Those sensor plugs are weatherproof to keep water out, dust would not get past them, and the dust is probably just on the surface of the car, not throughout the engine compartment. If it's just clicking it sounds like a bad battery connection/ground or a dead battery to me - and they do just go bad sometimes. First clean off the terminals and the connectors on the cables. Try again. If still no dice, hook up a voltmeter and see what it reads as you try to crank the car. I believe anything under approx. 10v is bad. If that's the case get a new battery.
Old Oct 10, 2009 | 02:45 PM
AtHomeSoda's Avatar
AtHomeSoda
Default Well..
How old is the battery? And my guess is a cell died... it won't charge. You CAN pull the battery, drive to AutoZone, they will test it. If bad, you can get a 84 month battery for $100, with 3 year Free Replaclement, no pro-rate. I did.. been great..
Old Oct 10, 2009 | 08:22 PM
phoenix's Avatar
phoenix
Original battery 1.5 yes old. Should this still be on warranty?
Old Oct 10, 2009 | 08:26 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
could be, but don't hold out a lotta hope. I agree with LMB tho and suggest you do as he suggested re cleaning, checking, loosening and re-tightening, etc. But I also think I read somewhere that below about 11.5 or so and the battery's toast.
Question: has this happened before?
Old Oct 10, 2009 | 09:04 PM
phoenix's Avatar
phoenix
Never before. Totally out of the blue. I'll try reconnecting tomorrow. If that fails then new battery.
Better than AAA towing it!!
Old Oct 11, 2009 | 08:24 PM
phoenix's Avatar
phoenix
No dice. Disconnected and reconnected the battery cables. No change. New battery, still won't start. It doesn't even turn over. I get a click and that is it.
Check engine light is on and the code is 1642 (unknown on my reader).
I guess that I will have it flatbedded to the dealer in the morning.
Old Oct 11, 2009 | 08:43 PM
LMB-C6's Avatar
LMB-C6
Are you sure it's 1642? I don't even see that in the service manual...but they way it's set up I could just not be finding it.
Old Oct 11, 2009 | 10:32 PM
phoenix's Avatar
phoenix
Sorry, you are right. I rechecked it. The code is 1682. Is that in the service manual?
Old Oct 11, 2009 | 10:55 PM
Donny T.'s Avatar
Donny T.
It's the starter. I know you hear clicking. Same thing happened to me. Crankshaft sensors came up on the scanner and it threw me off. Check it out. Could be an old fashion fix.
Old Oct 12, 2009 | 10:10 AM
phoenix's Avatar
phoenix
I think that you are right. I tested the voltage and it has to be the starter or in the connections beyond the starter.
I had it flatbedded to the dealer this morning for the warranty work.
I should have it back later today.
Old Oct 12, 2009 | 10:27 AM
Mad*Max's Avatar
Mad*Max
Did you put it into "ignition mode" and see what voltage the DIC is saying? Anything less than about 11.6 volts I noticed it has difficulty starting.
Old Oct 12, 2009 | 11:11 AM
haljensen's Avatar
haljensen
DTC1682.
"The ECM detects that the voltage level difference is greater than 3 volts between the run/crank and the ETC ignition 1 voltage circuits for more than 3 seconds".
2 pages of steps to follow to test and clear. One of the things mentioned is a fuse in the underhood fuse block for the ECM.
Note that all tests assume a fully charged (12.6 volts at rest) battery.
New batteries don't always have a full charge, old batteries sometimes have to be disconnected from the car to be charged.
Old Oct 12, 2009 | 09:06 PM
LMB-C6's Avatar
LMB-C6
I'd still like to know what the voltage drop was when trying to start the car - that may have helped in diagnosing this further. Just in looking at the schematic for the starting circuit, if the starter is clicking and not turning over then there is not enough energy to power it, or it's gone bad, or something is causing the engine not to rotate freely. The manual states that a resistance of as little as 5 ohms in the circuit or underhood fuse block is enough to set P1682 - that's not a lot of resistance. My bet would be a bad connection/corrosion in one of the connections. Let's see what the good Mr. Goodwrench says.
Old Oct 12, 2009 | 09:26 PM
inthehunt2's Avatar
inthehunt2
Hold the show! I had this happen on my TrailBlazer once! It turned out to be the starter solenoid (my solenoid was IN the starter). I did a test and used a screwdriver to jump the solenoid and the starter kicked over and the engine started. After that, the starter worked fine for about a week then died again. Took it to the dealer and it was a bad solenoid.
Hope this helps.
To Need help, won't start
