Steam Cleaning Engine
Old Oct 11, 2009 | 08:25 AM
vtech's Avatar
vtech
Default Steam Cleaning Engine
Has anyone done this before on a C6- I liked to spray out my engine compartment and steam clean the engine.
Not sure with all the sensors around the motor if this is a bad idea or I it will be okay.
If you have suggestions and feedback I would appreciate it - if it can be done safely - what recommendations to you have on covering certian componets.
Old Oct 11, 2009 | 10:14 AM
ryoder's Avatar
ryoder
Before doing that, why not use a hot wet towel with some dish soap?
I have done this and the engine loves it.
Old Oct 11, 2009 | 10:18 AM
STRAFER's Avatar
STRAFER
Default rag and simply green
dont steam or use a high pressure spray. i use an old rag sprayed with watered down simply green. do it 2 or 3 times a year, your engine will look new
Old Oct 11, 2009 | 11:54 AM
cmonkey713's Avatar
cmonkey713
I would not steam clean the engine. Too many electronic components in the engine bay to potentially damage. Just use the simple green route with limited amounts of water. Stay away from the electronics any you should be fine. Don't get in a hurry and just take your time. A day spent with your Corvette is a day well spent.
Old Oct 11, 2009 | 12:03 PM
cclive's Avatar
cclive
You shouldn't need steam to clean the top of the engine unless something is wrong and its leaking. The underside of the engine would be the only place that I would use a steam cleaner because there might be enough grease there to need it, but I would be surprised if any C6 would be old enough at this point to need steam cleaning.
I use 409 in a spray bottle on the top of the engine and engine compartment. With the engine warm, like an hour or two after driving, I gently spray down the engine compartment with a hose....water just pouring on it, not spraying hard. I cover the air filter and alternator with rags. The I spray 409 and let it sit for a minute or so, then gently rinse off. I dry with an air compressor and then take the car for a short spin to dry the rest.....and it is a good excuse to go for a short spin!
Old Oct 11, 2009 | 12:07 PM
EuroRod's Avatar
EuroRod
Only if you wish to use the engine as the base for a table afterward! Agreed........... too many sensitive electronic connections and senors. Even a hand wash can cause issues that are a PITA to correct.
Old Oct 11, 2009 | 12:09 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
I typically warm the engine up, then spray it down with Simple Green, hose it off and then dry it with a towl. Just don't get water on the headers when they are hot. Should look new again.
Old Oct 11, 2009 | 12:18 PM
vtech's Avatar
vtech
Default Follow up
Thanks guys, I love this forum - always know I can depend on great advice.
Old Oct 11, 2009 | 12:53 PM
CQRT's Avatar
CQRT
Simple Green works well . . just stay away from the serpentine belt, fuse box and other obvious electronic centers, then hose off. Several people use blowers of one sort or another - - I use a towel and follow the process with tire foam spray on the plastic and rubber parts - - again, avoiding the serpentine belt-- then wipe to reducing spotting.
Works well too in the wheel wells - - I remove the wheels once or twice a year - - you could probably use a pressure washer or steam cleaner on the wheel barrels and the wheel wells - - tire foam works well on the plastic fender liners as well. Just depends how picky you are about these things and how much time you've got on your hands.
And while you've got the rear wheels removed, you might want to check your rear axle nuts - - do a search, there are several well-informed posts.
And hey - -post pics when you're finished- -
To Steam Cleaning Engine
