Flat Tire Warning
It has happened a couple of times and I get out and check the "runflats" (which seem to be known as "runcr@ps") and they have plenty of air in them. When restarted, the warning usually goes away. More of an annoyance than anything, but I was curious if this is common. I was thinking it might be a bad sensor in the valve stem. (It always says LFT Front is Flat)
thanks
I'm about due for service so I will have the dealer fix the problem, the third attempt.
thanks
Is it low or are you at 30psi ?
Driving along slowly in Long Island traffic, all of a sudden I get a "flat tire" warning, "left front", "maximum speed reduced to 55mph, etc". Car felt fine. I then checked the DIC and it showed that all four tires had correct air pressure. I continued driving, eventually getting up to highway speeds, car felt perfect, zero evidence of a tire with low or no air pressure. I was able to hit 70mph on the highway and cruise with no problem. Was just a false alarm.
Never had any issues with the TPM system before. Wondering now if, being that my sensors are over 6 years old, the sensor batteries are ready to throw in the towel. Tires are still in decent condition, probably about 50% tread left, would be a real pain to have to dismount and remount all four tires (and rebalance) just to change the TPMS. I guess I'd probably just mount new tires at that point and be done with it.
Or maybe the sensor batteries are fine and I just merely experienced a random, one-time little "glitch". Car has been perfect otherwise.
Anyway, just reporting it.
Checked the pressures and all was well. Got so tired of it I installed a new TPM in that wheel and never had the issue again.
Interesting. Yeah, that certainly does sound like a bad sensor... and was.
My flat tire warning DID come on at a very slow speed, was barely moving... and then I soon started moving faster, the warning went away and I never saw the warning again. I then drove another 50 miles at assorted speeds, stoplights too etc, no issues. Maybe little by little it will start to act up at slow speeds / stoplights more and more... we'll see.
This is not a serious problem, unless of course the computer should continue to think that the car has a flat when it doesn't and limits your speed to 55mph. That would stink if you're on a long distance trip and now couldn't go over 55mph. But that hasn't seemed to have happened to anyone here, at least in this thread... good. So, fortunately this issue may just turn out to be an annoyance at best.
I need to research, I used to know but forget now, what is the "official" service life of a Corvette TPM sensor? I know that the batteries are not replaceable so after a certain amount of time you just toss `em and install new ones. So, what kind of time are people getting out of these sensors? 2005 and 2006 owners, have you had any TPMs go dead yet (battery failure) from age / use? I am hoping the official service life is like 10 years... I can live with that.
http://forums.corvetteforum.com/foru...s-or-more.html
