Window indexing
Old Oct 14, 2009 | 09:20 AM
vettenut's Avatar
vettenut
KY Events Coordinator
Default Window indexing
When I close the passenger door on my 2008 the window indexes up and down six or eight times before setteling down. This has just started. What can be done about this?
Old Oct 14, 2009 | 09:34 AM
TBD's Avatar
TBD
It's a bad door switch. Same happened to me. Contact your dealer; likely they will need to order part but it IS a very quick repair. Quite a common problem...
Peace, out.
Old Oct 14, 2009 | 09:48 AM
vettenut's Avatar
vettenut
Thank you! Your answer is an prime example of what Corvette Forum is all about.
Old Oct 14, 2009 | 12:11 PM
cclive's Avatar
cclive
Here's the TSB on it...
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)Models: 2007-2008 Cadillac XLR2007-2008 Chevrolet Corvette ________________________________________ ____________________________________This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).___________________________ _____________ ___________________________________Condi tionSome customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.CorrectionDiagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.Parts Information Part Number Description10446243 Front Side Door Handle SwitchWarranty InformationFor vehicles repaired under warranty, use: Labor Operation Description Labor TimeN9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
Print it out and take it with you so they will replace both sides, as it says.
To Window indexing
