Problem with new C6
Old Oct 17, 2009 | 10:25 PM
camarochevy1970's Avatar
camarochevy1970
Default Problem with new C6
Folks, I just picked up my car today, and did not notice this issue until it got dark. My third brake light glows all the time. When you hit the brake it lights up like normal, but otherwise, you can see it is somewhat powered all the time. I found that if I pull fuse 56, the ecm/TCM/Easy Key MOdule, then the light goes out.
Does anyone know what it might be?
Old Oct 17, 2009 | 10:29 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
Congrats on the new car. Someone here will know. It's a great place.
Old Oct 17, 2009 | 10:32 PM
vettedoogie's Avatar
vettedoogie
Congrats and I hope someone can help you with that...I haven't seen it myself. Best of luck!
Old Oct 17, 2009 | 10:35 PM
camarochevy1970
Thanks guys, keeping my fingers crossed. I hate to think that my new car has an electrical gremlin...
Old Oct 17, 2009 | 10:37 PM
bksnoopy's Avatar
bksnoopy
I hate taking my car to the dealer but that's what you might have to do.
Congratulations on the new C6 .. Things will work out fine, that's why we have a warranty.
If you’re not happy I think you have the 60 day return deal, if you’re in that time line?
Ben, OH
Old Oct 17, 2009 | 11:03 PM
haljensen's Avatar
haljensen
Is the car never Titled new or new to you? Possible that someone has "modified" the third brake light?
Old Oct 17, 2009 | 11:22 PM
camarochevy1970
never titled, had 28 miles on it when I drove off the lot
Old Oct 17, 2009 | 11:34 PM
haljensen's Avatar
haljensen
Then it's a Dealer problem!
Old Oct 17, 2009 | 11:45 PM
cclive's Avatar
cclive
Corrosion in the wiring harness plug near the taillights....reported here before....easily fixed with a good cleaning of the plug....are you in a humid area of the country???
Old Oct 17, 2009 | 11:53 PM
rdm1465's Avatar
rdm1465
That would be my guess also. Or possibly a loose gound connection.
jpuli28's Avatar
jpuli28
I got you bro...
I had the same thing, except when I pulled the fuse the light did NOT go out.
Went to dealer and they found the connector/wiring had corroded and fused together with something (I dont recall what) supplying constant low current voltage.
Warranty took care of it.
Old Oct 18, 2009 | 04:02 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
If you're going to DIY, it might be a good time for your first mod..............Painted spoiler/3rd brake light housing and/or one using LED's.
Old Oct 18, 2009 | 06:43 AM
metal's Avatar
metal
New car + brake light problem = return to dealer for correction.
(congrats on new car)
Old Oct 18, 2009 | 09:10 AM
camarochevy1970
You guys were spot on, the connector for the tail lights appears to be the source. I unplugged it, cleaned it up, and put it back togethor, and we are all better. Thanks guys!
Old Oct 18, 2009 | 12:40 PM
cclive's Avatar
cclive
Glad it worked out!
Old Oct 18, 2009 | 01:11 PM
mpuzach's Avatar
mpuzach
Nicely done, Chris!
Old Oct 18, 2009 | 01:13 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Let this be your dealers problem.........
Old Oct 18, 2009 | 02:40 PM
CQRT's Avatar
CQRT
Drive it back - - -bad switch down by the brake pedal....covered under warranty . . .EZ fix.
Welcome to the forum.
Old Oct 18, 2009 | 04:11 PM
RPHCRMZ51's Avatar
RPHCRMZ51
One on One time with the Vette
Just think what the dealer could have screwed up for such a simple fix.
To Problem with new C6
