Weird thing
Old Oct 18, 2009 | 04:23 PM
SRQStingray's Avatar
SRQStingray
Default Weird thing
Today, I noticed one of my DRLs was glowing orangish while the other is yellowish. Does anyone have a similar issue? I'm not even sure how to change the bulb. I have had a couple of cars that the owner's manual said to go to the dealer for headlights. I'm hoping that's not needed.
Old Oct 18, 2009 | 06:20 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sounds like the coloring on the lamp is flaking off. No clue how to change them yet as I haven't had to.
Old Oct 19, 2009 | 05:05 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
The Owner's Manual explains/shows how to change the bulbs and gives the replacement bulb numbers.
Old Oct 19, 2009 | 11:15 AM
Zymurgy's Avatar
Zymurgy
Moderator
To replace a high-beam or front parking/turn signal/DRL
bulb, do the following:
1. Turn the wheel to allow access to the wheel well.
2. Access the high-beam or front parking/turn signal
bulbs by removing the access panel. To do this,
remove the three outer fasteners and flip back
the cover.
3. Remove the outer cover to expose the high-beam
headlamp bulb socket once the access cover has
been removed.
4. Remove the headlamp bulb by releasing the
outer tabs from the socket.
5. Remove the front parking/turn signal bulb by turning
the bulb socket counterclockwise.
6. Replace the high-beam headlamp bulb with a new
bulb and reattach to the bulb socket.
Replace the front parking/turn signal bulb by turning
the bulb socket clockwise.
7. Reverse the Steps 2 through 4 to reinstall.
Exterior Lamp ............... Bulb Number
Front Parking/Turn Signal/DRL .. 5702KA
Headlamp, High-Beam ............ H9
Sidemarker ..................... W3W
Stoplamp/Taillamp/Turn Signal .. 3057KK
Old Oct 19, 2009 | 03:02 PM
HANNY's Avatar
HANNY
easy to change and i would try that first. make sure to turn the wheel all the way and it will be much easier to take loose the inner fender covers
To Weird thing
