CD Changer
Old Oct 18, 2009 | 06:42 PM
vettenut's Avatar
vettenut
KY Events Coordinator
Default CD Changer
I have a Delco 6 disc CD changer in my 2008 in a rear well bolted to the bottom. When I hit a bump in the road, it skips. Has anyone found a fix for this? If so, I would appreciate details on eliminating this problem.
Old Oct 18, 2009 | 07:29 PM
K9KUZ's Avatar
K9KUZ
No solution, but you might try un-bolting it and put a piece of soft foam about 1" thick under it. Then go for a bumpy ride and see what happens. If OK, then put something around it, perhaps some hard foam, to keep it from sliding around. good luck.
