Are Tail Lights Interchangeable?
Old Oct 18, 2009 | 09:29 PM
Cool Rod's Avatar
Cool Rod
Default Are Tail Lights Interchangeable?
This might be a dumb question, but are the tail lights specific to one side or the other?
I pulled my outboard lights to install sequential flashers which involved setting the taillight assemblies off to one side of my work area, and now that I've put them back in they seem to point to the sides instead of straight back. I wonder if I put them back in the opposite holes.
They look dimmer than the inboard lights unless you stand off to one side. I didn't notice this before I installed the flashers.
I'll switch them tomorrow when I have daylight, but I thought I'd see if anyone knew if there is a left light and a right light.
Old Oct 18, 2009 | 10:20 PM
cclive's Avatar
cclive
Both lefts are the same and both rights are the same, but there is a left taillight and a right taillight. In the writing at the bottom of each taillight, the last character is either an R or an L.....So the two on the left should both be 'L', etc.
If they are switched, they will fit, but will not be aimed correctly for viewing from behind.
Old Oct 19, 2009 | 05:23 AM
Cool Rod's Avatar
Cool Rod
Thanks Chris.
I made sure that I kept them separated from each other when I moved them, but then I just spaced out and picked up the closest one and put it in. Doh!
Old Oct 19, 2009 | 08:26 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
I did the same thing and had to change them
To Are Tail Lights Interchangeable?
