Start up noise in engine
Old Oct 19, 2009 | 12:26 PM
TY'Z Vette's Avatar
TY'Z Vette
Default Start up noise in engine
When i start the engine... most of the time i hear the engine rattle for a second or two then the oil circulates and sound normal.... until it gets hot!
When the temperature gets high like 210 plus.. the engine sounds loose and clacks a bit, like the start up.
The oil pressure seems good... cold start like 40-42 and when its hot like 26-28 both at idle..
The car only has 18500 miles on it and i change the oil every 3K.. (Mobil One) Synthetic..the oil in it now is about 500 miles old
Does anyone notice the same type of situation or should i take it to the dealer....
Thx Ty
Old Oct 19, 2009 | 12:48 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
good question, may want to post it in the Tech Section.
Old Oct 19, 2009 | 12:58 PM
TY'Z Vette's Avatar
TY'Z Vette
Ok... looks like dealer time
Old Oct 21, 2009 | 03:03 AM
2006c6keller's Avatar
2006c6keller
Default ???
Some Vettes are noisy for awhile on start up and then it goes away, like a lifter or piston slap.
Old Oct 21, 2009 | 04:13 AM
JSB2008's Avatar
JSB2008
A bit of clatter on start up is usually normal. What you might have is a clogged injector that can cause the knock when hot sound. Take it in have the dealer look at it.
Old Oct 21, 2009 | 04:26 AM
07c6vette's Avatar
07c6vette
Originally Posted by 2006c6keller
Some Vettes are noisy for awhile on start up and then it goes away, like a lifter.
once warmed up, it's gone
Old Oct 21, 2009 | 04:01 PM
2006c6keller
Default Also possible piston slap!
I expanded my post by adding piston slap in addition to lifter. Post #4.
Old Oct 21, 2009 | 05:35 PM
Vinnie T's Avatar
Vinnie T
What brand of oil filter are you using? Frams are notorious for bypass valve leakage when the engine is off and losing pressure. Had a 5.0 Mustang once upon a time that did this on startup. It was totally gone after changing brands of filters and have never ever gone back to a Fram. The ominous part of your story is the hi-temp noise which sound like something with excessive clearance.
To Start up noise in engine
