Skip shift eliminator
Old Oct 19, 2009 | 02:09 PM
Spaghetti's Avatar
Spaghetti
Default Skip shift eliminator
I hope this hasn't been asked before, but I'm sure I'll find out..
I am considering trading in my C6 A6 Z51 and go for the manual transmission. Do you suppose the dealer service department would install the skip shift eliminator if I purchased the part and paid for installation labor? I don't have access to a lift so if they didn't do it, who would you recommend?
Old Oct 19, 2009 | 02:26 PM
PJRed2008's Avatar
PJRed2008
As it disables a GM "feature" I doubt if they would install it. However, if you go the smartfuse route, you don't need a lift and can save some money as it installs in the main fuse panel under the hood.
Old Oct 19, 2009 | 02:39 PM
JJC5's Avatar
JJC5
It is so easy to install it yourself. You don't need a lift either.
Old Oct 19, 2009 | 02:44 PM
Spaghetti's Avatar
Spaghetti
Thanks guys --- sounds like a "can-do" job. Are most people going with the fuse type or transmission mounted type? Any advantage or disadvantage to each?
Old Oct 19, 2009 | 02:46 PM
bimmerborn's Avatar
bimmerborn
There are at least couple of ways to disable CAGS AKA Skip-Shift. One is the Skip-Shift eliminator module installed near tranny, and the other (easier one) is swapping a special fuse for CAGS. Please do a search on "smart fuse"
Old Oct 19, 2009 | 02:47 PM
Spaghetti's Avatar
Spaghetti
Roger that ---- thanks!
bimmerborn's Avatar
bimmerborn
Bought the module for transmission and have it, but after building my own smart fuse and replacing it, there was no need to install the module on the tranny.
Old Oct 19, 2009 | 02:52 PM
Spaghetti's Avatar
Spaghetti
Who sells the CAGS smart fuse?
Old Oct 19, 2009 | 03:08 PM
Joe_Planet's Avatar
Joe_Planet
you can also go the non retarded route and get the potted plug connector that installs onto the trans harness. all you do is jack up the rear of the car and plug it in. people have been known to sometimes get a CEL with those ghetto fabulous blown fuses...
Old Oct 19, 2009 | 03:56 PM
Spaghetti's Avatar
Spaghetti
So from what I can gather, it appears that the transmission harness is more reliable than the smart fuse ---- correct?
Old Oct 19, 2009 | 05:48 PM
George's_Vette's Avatar
George's_Vette
Default Install
My dealer offered to let me install mine to the transmission while the car was up on their lift getting a warranty alignment. I didn't have it with me so backed it up for a few minutes on my Race Ramps and the install was quick and easy as expected.
George
Old Oct 19, 2009 | 05:54 PM
Boz86's Avatar
Boz86
I would recommend driving it without the eliminator and see if you really need/want it. I find it engaging only rarely, usually in stop and go traffic, and I just take it up to third gear.
Old Oct 19, 2009 | 05:55 PM
diverdan's Avatar
diverdan
I've had 5 cars with the transmission plug CAGS-Defeat (CAGS=Computer Aided Gear Select) and never had a problem with any of them. Installs on all of them only took a matter of a couple of minutes.
Old Oct 19, 2009 | 05:57 PM
GotChrist?'s Avatar
GotChrist?
Go to your local auto parts store and buy a Smart Fuse or clone. It has an LED in it to alert you that it's blown. The LED provides the resistance necessary to run a blown fuse as a CAGS eliminator. Buy the Smart Fuse, hook it across your battery or to a battery charger so it blows. You won't hear or feel a thing, the LED will illuminate. Remove the CORRECT fuse and install the blown Smart Fuse. Whalah! Done. If you blow a standard fuse the system knows it and will set a DIC alert &code. With the LED providing proper characteristics, the tranny solendoid is not engaged and the car thinks everything is functioning as it should.
Last edited by GotChrist?; Oct 21, 2009 at 11:16 AM. Reason: Spelling/grammar correction
Old Oct 19, 2009 | 06:09 PM
Nutshell's Avatar
Nutshell
Buy some ramps, CAGS install on the transmission took me 2 mins, and I hardly EVER work on cars. An oil change is about the maximum extent of my skills, lol.
Old Oct 19, 2009 | 06:37 PM
richgoat's Avatar
richgoat
Originally Posted by GotChrist?
Go to your local auto parts store and buy a Smart Fuse of clone. It has an LED in it to alert you that it's blown. The LED provides the resistance necessary to run a blown fuse as a CAGS eliminator. Buy the Smart Fuse, hook it across your battery to to a battery charger so it blows. You won't hear or feel a thing, the LED will illuminate. Remove the CORRECT fuse and install the blown Smart Fuse. Whalah! Done. If you blow a standard fuse the system knows it and will set a DIC alert &code. With the LED providing proper characteristics, the tranny solendoid is not engaged and the car thinks everything is functioning as it should.
I have on i bought from another forum member, and I get a check engine light. So, I removed it. I'll have it bypassed when i get a tune.
Old Oct 19, 2009 | 08:07 PM
Rule292's Avatar
Rule292
St. Jude Donor '11-'12-'13-'14-'15-'16
The dealer service department most likely will not install a skip shift eliminator for you.
It's illegal for them to defeat emissions related devices and your government has mandated that CAGS be used to meet emissions and CAFE and "gas guzzler' laws. There is a hefty fine awaiting them if they install it and get caught.
If you have the ability to solder you can make the famous Leres CAGS elimination fuse that you don't have to crawl under the car to install.
To Skip shift eliminator
Old Oct 20, 2009 | 08:29 AM
Spaghetti's Avatar
Spaghetti
Everyone has provided some very interesting information and I appreciate the responses. Many have mentioned on this site that they shift from 1st to 3rd (which is what I like to do in traffic anyway), but the owner's manual states that with skip-shift, it can (or should) only be shifted in to 4th (when the light comes on) to prevent damage to the transmission. Is this truly the case or is it just stated in the manual because the manufacturer needs to tow the government line? Shifting into 3rd gear is not a bad option if that is possible and if it is not blocked out by the CAGS system as well.
Old Oct 20, 2009 | 08:41 AM
Rule292's Avatar
Rule292
The CAGS is necessary because of the CAFE law change that created the "gas guzzler" tax. Without the CAGS "skip shift" the car purportedly would not meet the federally requred fuel economy standards and would be subject to the "gas guzzler" tax.
It really has nothing to do with damaging the transmission.
And I too have "skip shifted" long before the feds mandated it.
Old Oct 20, 2009 | 08:49 AM
Spaghetti's Avatar
Spaghetti
Yes, but does the skip-shift mechanism actually block a 1-3 shift? As previously stated, many drivers seem to be able to do it but the manual says it can't be done.
